HFR_Racer's Avatar
Talking 1st engine drop (and I did it single handed).
Like a walk in the park everyone..
Now I'm wondering if I can get it back in myself as well. Sorry.. No pics yet..
Enjoy,
HFR_Racer
Thank you,
HFR_Racer
'87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups.
Old 10-11-2006, 07:25 PM
Detached Member
Hugh R's Avatar
Let me be the first to say congrats! I pulled mine for the first time by myself last xmas break. Not terribly hard, but not like any other engine I've ever pulled. I used an engine hoist to lift the rear of the car versus getting it way up in the air with jackstands. Much safer I thought, and I had the engine hoist so I didn't need to buy the RV jackstands. Gotta love them Targas!
Hugh
Old 10-11-2006, 08:02 PM
I'll be the second to congratulate you. Putting it back in solo isn't as easy, but doable.
Marv Evans
'69 911E
Old 10-11-2006, 08:52 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Congrats!
I have this looming in my future...sometime in the next year.
All of the threads here will help guide me through it along with the Bentley manual and Wayne's books.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 10-11-2006, 09:38 PM
sww914's Avatar
Just don't be afraid. Even if the next to worst thing happens- you drop the engine on the ground- usually nothing gets very messed up. If the worst thing happens- you drop it on yourself- things get more messed up.
Old 10-12-2006, 12:43 AM
Wer bremst verliert
JohnJL's Avatar
always throw the wheels under the car when jacked up for xtra safety. I put mine back in, awkward but nothin' but leverage involved.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-12-2006, 02:06 AM
Wow Hugh!!
That's a great idea.
I have a engine hoist.
But I have a question.
Where exactly did you pick up the rear of the car?
Old 10-12-2006, 03:57 PM
Detached Member
Hugh R's Avatar
Take out the engine mounts and make a plug with a lifting eye hook that is bigger than the engine mount holes and mount underside. DON"T lift through the mounts themselves, they'll probably rip out.
Hugh
Old 10-12-2006, 04:13 PM
HFR_Racer's Avatar
Thanks for the kudos..
Thanks everyone for the congrats...
I have a helper to put it back in tomorrow.. I just dropped it to clean it up, check for the common leaks, adjust the valves, etc..
I think I may need a shifter shaft seal and that's about it. I'm not seeing any leakage between the jugs and block so I hope this means no broken head studs on the exhaust side.
Enjoy,
HFR_Racer.
Thank you,
HFR_Racer
Old 10-12-2006, 07:01 PM
Licensed User
Shuie's Avatar
If you didn't already use one to do the drop, go buy an ATV jack for the reinstall.
Old 10-12-2006, 08:56 PM
HFR_Racer's Avatar
All is well.. No broken studs..
No broken head studs found at 60k miles. Valves adjusted. Engine and transmission cleaned up and shifter rod seal installed.. Time to re-install..
HFR_Racer
Thank you,
HFR_Racer
Old 10-15-2006, 06:03 PM
Zeke's Avatar
I think I understand you, but could you say that again differently? Are you saying you held the motor up while you replaced the bolts with forged eye hooks and then put a chain between them to lift the rear of the car? If so, did this not put an undue lateral strain on the mounts?
Maybe I'm lost here.
Old 10-15-2006, 06:18 PM
