Explain difference betwen Headers and Heat Exchangers
Headers vs Heat Exchangers please explain the difference ..
PS note I won't be using the cabin heater - ever Cheers
Euro 1989 Carrera 3.2 Paint Code L 693 Stone Grey 45,000 kms logged |
the heat exchanger is just a sheet metal sheath fabricated to fit around the header portion of the exhaust. Fresh air is forced between the sheath and header where it picks up heat on it's way to the cabin
so
So.... - what is their function? - just to provide hot air to the cabin?
I live in the tropics - would you disguard them. My goal is - twofold Reduce weight Improve sound (will add a SS muffler) I Don't track the car, and dont need any more power :-) ![]()
and yes, equal length tuned headers would be a subset of the general category headers
Thank you
Any brand ? Headers?.......... Muffler 2 in (one out ?)...dont want to modify the undercarriage Cheers Rich
I'd recommend SSI heat exchangers (which are equal length tube headers). I don't think the weight penalty is that great for the thin sheetmetal on the SSI's, and the heat may help if you ever need to defog the windshield.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Heat
The heat exchangers also disapate heat from the headers as well.
Its better to get the SSI's and a good muffler. I have the Burshe and I am extremely happy with it (2 in 1 out). Chris
Signature Phrase " CATCH ME IF YOU CAN" 1988 Porsche 930 "Squerly" Built by "Porsche Doc" -------------------------- 1974 Porsche 911 (2003 - 2012) 2000 Boxster S (2006 - 2008) |
SSI heat exchangers are a stainless steel version of the factory heat exchangers. The factory HEs are fine too as long as they're intact (no rust-through), but they won't last as long as the SSIs (although my factory-original HEs are still alive..... not sure about my brain cells though)
![]() Sherwood |
As Steve alludes to, you must be able to get away with no cat to do the SSIs with a non-customized 2-in muffler. Some folks have custom built a cat/muffler combination, but as far as off the shelf mufflers are concerned, there's no cat in the equation.
Most folks will recommend SSIs. Not having any heat is normally reserved for track only cars and will no doubt effect resale value. SSIs are of superb quality and agree with Steve again that the weight penalty is minimal. WRT mufflers, your chioces are many: Stock 2-in, Dansk, Monty, B&B, Fabspeed, M&K, etc. All are of decent to really nice quality and come in more than one configuration (i.e. 2in1out, 2in2out, sport, etc.). To further complicate the choice, they all sound different. WRT the chip, you may as well do it if you're going with a new exhaust setup. Steve Wong will hook you up. Good luck.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
Thanks Ben at M+K has been helpful...
Hooked up with Ben at M+K who has been brilliant
Great help thanks guys
You should do a search on this board, but many have said that SSIs are too small for a 3.2. That would leave you with headers or B&B heat exchangers with primaries measuring 1 5/8".
Has anyone or any company fabricated a HEADER + Catalytic combo, so it will pass the visual smog inspection in Calif? Where can i get one?
I assume catalytics are needed to clean up the exhaust gases for the smog emissions test. Otherwise a Header + Cat bypass would be ideal, so it'll pass the visual. thanks
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
Mike I would think that the combo of Headers and Cat would be self defeating.....headers allow free flow of the exhaust...The cat traps the exhaust (somewhat) to clean it. At least that's what the guys at the pool hall told me.
Howie 79SC |
