Brillo's Avatar
Unhappy
Originally posted by Formerly Steve Wilkinson
Interesting! And I thought I was the only one who had this problem. Even installed a new switch, no improvement, was beginning to worry that I had something faulty.
Same here.
Ray H.
1979 911SC Coupe
2000 986
Old 10-13-2006, 04:42 PM
Okay, so _nobody_ has an opinion whether or not the entire problem is due to failure to "bleed" the brakelight switch before installing them? That'd be a first.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-13-2006, 05:17 PM
Steve:
Okay then....The premise makes sense....air is compressible...a liquid fluid is not ...and would hydraulically transmit forces better/more directly. So a bleed might be in order...how would you do that and not lose the fill while installing?
Jack O...nice find...
Andrew..also nice...the switch is "pushed in" in the static normal position and is "allowed-out" upon brake pedal pressure....has to be very effective and quick, especially since you can probably adjust the position of the switch and therefore its sensitivity...when it activates. I would try to hide/protect the wires a bit more, though.
-Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-13-2006, 05:29 PM
pmajka's Avatar
Yes, failure to bleed the Wet switch...I put new ones in and same results...but, am betting there is a bubble.
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 10-13-2006, 05:45 PM
Wil, I should think you could pop the switch into place quickly enough that no fluid would run out before you got a thread engaged, since it's moderately viscous. I'm gonna try it.
Stephan Wilkinson
Old 10-13-2006, 06:18 PM
.... or have a helper slowly press the brake pedal to create positive pressure in the MC as you R&R the switch. That way, air (and some fluid) is expelled during the process.
I'd think seriously of using a mechanical switch if pressure switches present this much of a hassle (non-adjustable, limited life).
Sherwood
Old 10-13-2006, 06:40 PM
madmmac's Avatar
Smile
I have an 84 which precludes the 3rd brake light and would be interested in the battery operated (no wiring) motorcycle led's.
Has anyone tried them?
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 10-13-2006, 08:30 PM
Won Won is offline
Won's Avatar
Stephan, please let us know if bleeding the switches makes any difference, I'm very much interested! I would think the viscosity and capillarity would keep the fluid inside the bore.
My mechanical switch is set up so that the lights would turn on just as the slack in the pedal bushings and linkage are taken up. I would much rather have it come on too early than too late.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 10-13-2006, 08:59 PM
Won asked me to report back on my experience with "bleeding" the brake-light switches before installing them.
Bad news: makes no difference.
I had a pair of good switches among my spares, so I dripped brake fluid into them and left them on the workbench for an hour, sitting erect (of course), to ensure that the fluid went into them. Even prodded them gently with a thin wire to ensure that there wasn't a trapped air bubble.
Pulled the old ones out and instantly installed the new ones before the brake fluid had a chance to run out--it's viscous enough and in a small enough hole that it really doesn't want to run out anyway--but it made no difference to the brakelight-on time.
It was also obvious that the switches I pulled out were full of brake fluid--no trapped air bubble either.
I'm goin' to a mechanical switch. I've also ordered a pair of those motorcycle inertia LED clusters that Jack Olsen led--no pun--us to.
Stephan Wilkinson
Old 10-16-2006, 10:28 AM
Driving member
jester911's Avatar
I swapped mine out a couple years ago the same way formerly Steve did. They are just about back to the way they were before.
It takes more and more pedal pressure over time to activate.
I am about ready to do a mech switch as well.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 10-16-2006, 10:41 AM
MBruns for President
JeremyD's Avatar
Mine takes more effort too - especially with 993 calipers and a 930 MC - I'd love to see an easier solution to this!
Old 10-16-2006, 10:53 AM
Me like track days
Craig 930 RS's Avatar
For me the problem is two-fold:
1) Brake lights are too dim. No real solution for this - the LED deal realistically isn't that feasible or efficient.
2) Brake lights come on WAY too late and with too high of pressure - aka too hard/quick stop - required.
I plan to rig up a durable manual switch for the brake lights - ALONG with the inertia LED setups that Jack mentioned. Mine shipped today.
A 9XX that is rear ended....is often a total.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-16-2006, 11:06 AM
Administrator
Jack Olsen's Avatar
Any redundant solution is a plus. And I like Andrew's switch since when it fails the lights go on, rather than a failure where the lights don't go on. If Andrew's switch could be wired in parallel with the pressure switch (so that if either failed the other still triggered the brake light), I think it would be a big improvement. Any switch down by the pedal cluster that I could cause to fail by deliberately kicking is a no-go, in my book. Over time, lots of stuff can bounce around down there.
I bought the LED/inertia switch unit a couple of years ago. I actually bought it as a brake indicator for in-car videotaping, and put it somewhere... I have no idea where it is now, and I never ended up using it.
Old 10-16-2006, 11:42 AM
One semi-solution for the dimness of the brake lights--I have LEDs in RS taillights, but they're not for everyone--is the OEM later-model CHMSL, which I've also installed. (Pelican provided it.) It's pretty bright. A lot of people think they're dorky, but I think a rear-ended 911 is even dorkier.
Stephan Wilkinson
Old 10-16-2006, 12:17 PM
german switches work better than brazilian ones.
206 637 4071
Old 10-16-2006, 12:19 PM
Can the OEM non-power-brakes mechanical switch be fitted to a power-brakes car, i.e. an '83 SC? It's $80, so I don't want to spring for it without knowing... I don't like the kludge arrangements that have been posted here and elsewhere, and for the same reason Jack Olsen doesn't. Besides, they might be Brazilian...
Stephan Wilkinson
Old 10-16-2006, 01:09 PM
Ken911's Avatar
I had this problem on my carrera replaced the switches didnt do any good flushed brake lines with the power bleeder and the problem went away I think a small amount of air got trapped in the line near one of the switches.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 10-16-2006, 01:10 PM
On a great circle route
xlr8's Avatar
Dim Bulbs?
I replaced my original bulbs with 3496 krypton bulbs.
In the pics below the top pic is the original bulbs, the middle pic has the left bulb replaced and the bottom pic has both bulbs replaced.
bulb comparo
This website has a desciption of using highly reflective tape in the lens buckets to increase candlepower.
I have not tried the tape yet.
Russ
Old 10-16-2006, 02:15 PM
the early mechanical switches attach to a bracket on the pedal cluster housing which is not there on the later ones. so fab a bracket for it.
206 637 4071
Russ, where did you purchase those krypton bulbs? Are they just drop-in replacements? Details please! The referenced site is pretty Chevy focused.
Thanks.
-Terry
Old 10-16-2006, 02:36 PM
