KatoKato's Avatar
Automatic Door Lock Not Working
I noticed on my last drive that the automatic door lock would not engage the lock on the driver's side door.
I have to manually lock / unlock this door from the passenger side now.
I've read in earlier posts that there's a little plastic part that's most likely broken.
Anyone have any pics of this part or part numbers?
Also - I've never taken the door apart. How easy is this? I saw maybe three screws that I could remove. Do I just remove these screws and carefully take out the door liner?
Any help would be appreciated.
Thanks in advance,
Kato
Old 10-14-2006, 11:39 AM
KatoKato's Avatar
Re: Automatic Door Lock Not Working
Sorry ... the search forum function seemed to be knackered this afternoon. I've now found more than enough info to get the job done.
Old 10-14-2006, 05:35 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Kato,
I've done this several times.
In fact I did it again last weekend.
PM and I'll give you my phone number and I can walk you through it if you'd like.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 10-14-2006, 07:33 PM
