Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Lowering 964--just to verify
In searching, it seems that I can't lower my 964 the same way my 3.2 was lowered. There is no ride height adjustment?
I had a pro lower the 3.2, but I was going to try and do the 964 myself with the same setup. I have to get new springs?
Tyson suggested we could take off some part of an inch using the corner balancing bolts, but that's all.
Verify this if you can, because even though the handling of the car is super, it does look a little too stilted for my liking.
-kb-
Old 09-04-2004, 10:05 AM
Az911's Avatar
Send a message via AIM to Az911
To lower the C2 you will need lowering springs. Were as the carrera is lowered by adjusting the torsion bars.
72T RS look
96 993
Old 09-04-2004, 10:09 AM
10zz964's Avatar
i have H&R and bilstein sport on my 91 c2 cab.
lower the car about an inch. work great for me.
Cheers
instagram @tennster
Old 09-04-2004, 11:12 AM
thanks guys
-kb-
Old 09-04-2004, 01:22 PM
Retired in Georgia
Robert Coats's Avatar
Here's my '91 C4 before and after I installed Eibach springs:
The biggest challenge was getting the lower mounting bolt off the rear suspension. Took a 48" cheater bar and a loud CRACK, but it came out.
An impact driver is great to use to remove the top nut from the front strut.
I've got five kids, an Italian wife, and I (used to) write about lawn mowers. You think you have problems?
-Robert Coats
Old 09-04-2004, 01:45 PM
Bill Verburg's Avatar
You want coil overs w/ adjustable purchases
Bill Verburg
Old 09-04-2004, 03:33 PM
PRO Motorsports
Tyson Schmidt's Avatar
Stock 964's have adjustable spring perches. From the Factory, there is about 1-1/2" of threads showing, which will allow you to lower it with stock springs quite a bit.
But the H&R progressive lowering springs and some Bilstein Sport shocks are the way to go. Much better handling, and the ride characteristics actually feel better, IMO.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 09-04-2004, 04:27 PM
As long as you have the B style you are all set
Bill Verburg
Old 09-04-2004, 06:25 PM
Good article on lowering a 964
Bill Verburg
Old 09-04-2004, 06:38 PM
Sports Purpose 911 Driver
mjshira's Avatar
great thread. problem is for me I have a 1990! I will check tonight, maybe the PO changed them to the later version.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 10-16-2006, 08:15 AM
