Smart quod bastardus
fredmeister's Avatar
smart racing roll bar install
Does anyone have experience with the front and rear sway bars from smart racing?
I am interested in their performance versus Tarret or Weltmeister roll bars.
I am really interested in photos of how they install on a front of the 911 or 930 Turbo.
Any install information is appreciated.
Old 10-20-2006, 12:21 PM
I doubt if anyone could perform a blindfold test and determine the brand of sway bar installed. Besides, driving blindfolded would require installation of air bags and a roll cage.
Other than that, there's a quality issue as the price differences indicate. How much does this quality translate into a cost/benefit formula only you can decide based on your budget, actual needs and bragging rights. The difference might be in the geometry and the ease and range of making adjustments (although adjustment for most users is a one-time "set and forget").
If you're a track guy, I'd probably suggest one of the higher quality kits. For street use, it's a wash and up to you.
As for installation, they're all the same.
Sherwood
Old 10-20-2006, 12:59 PM
Cory M's Avatar
Do a search - this exact topic comes up about twice a month and has been discussed in great detail several times.
Old 10-20-2006, 01:37 PM
randywebb's Avatar
agree re the search - I also recall that one brand wieghs a tad less
and the SRP rear bar hangs down in the back a ways more than the others.
I'd say the contest is between SRP and Tarrett; I wouldn't waste time on the Weltmeister (which is what the PO put on my car - still there tho). The welt also uses US sized allen wrneches for one adjustment. Hate that...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-20-2006, 02:30 PM
Jeff Alton's Avatar
The Tarett bars are much much lighter. I have used both. They are both good quality products.
Cheers
www.turn3autosport.com
Old 10-20-2006, 05:34 PM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
I would suggest mounting the front srp bar about 1/4" rearward from the factory location, keep from interfering with the gas tank, at least for the 31mm bar.
Susp upgrade (sway bar porn install)
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 10-20-2006, 07:27 PM
89turbocabmike's Avatar
I have the SRP and the quality is incredible, well worth the extra cost IMHO. Good installation instructions also. The rear bar does hang down quite a bit and I was concerned about it scraping, but after 1 year of daily driving and countless speed bumps, not one scrape....and my car is really low.
Old 10-20-2006, 07:32 PM
don911's Avatar
I put on SRP bars a few months ago. Quality is top notch. I think the front installation on the SRP bars is a little different than the tarrets and requires tank removal. At least I couldn't figure out a way to install the inside plate without tank removal.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 10-20-2006, 07:59 PM
lateapex911's Avatar
I second and third the Smart comments. I too tried to do it without tank removal, but in the end I decided that it would be faster to just suck it up and pull the tank (a5 minutes) than it would to dork around further.
I took tons of pics, and can post if you'd like.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 10-20-2006, 08:21 PM
Garen's Avatar
I have the SRP bars as well. Awesome product. I installed them on my '87 930, and did take the tank out. Even though draining almost a full tank of gas (did this prior to spring, so couldn't drive the car!) was a pain, the effort paid-off, since it was easier to align the collars while sitting in the gas tank cradle.
The rear mounts for the bar on my 930 needed to be lowered by 1/4 inch, to clear the trans. This could just be a 930 thing, if I recall correctly.
Also, it would be very wise of you to upgrade the rear chassis mounts to the WEVO units (also from SRP). The stockers WILL break. Trust me...
Garen
Garen
GNdesignLLC.com - Automotive Art & Sculpture
Old 10-20-2006, 08:32 PM
Oh yea, Geran is right, I almost forgot...get the WEVO mounts!!!!
Old 10-20-2006, 08:35 PM
Thanks for the info......I was mostly interested in seeing the front sway bar mounts to the lower control arm with the SRP set-up. They seem to not use the stock U-tab on the control arm.....makes it not necessary to remove it? This is what I am not sure about and wanted to see pictures of it.
John Helgesen provided a great link to some photos thanks.
One othere question is the rear and front sway bar interchangeable with the SRP. If I used a heavier sway bar for the rear versus the front, would it be possible to swap them around if the car needed it?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-20-2006, 08:41 PM
Garen's Avatar
Yes. The bars are interchangeable. That's another benefit to these bars. You can get rid of the U tab. It is no longer used. The SRP drop link attaches to the diagonal bar. I'll try to find a pic for you.
Garen
Old 10-20-2006, 08:54 PM
Jeff Alton's Avatar
The SRP mounting to the a-arm is a good design. It allows you to mount it to late arms without having to modify them at all.
Cheers
Old 10-20-2006, 09:06 PM
Here's a view of my installation, showing the mount to the a arm. It's a two peice mount that clamps with two socket head cap screws. Super clean.
Old 10-20-2006, 09:17 PM
vroom vroom
Send a message via AIM to MaquinaVerde
I just installed the Tarrett front bar today and it went in very easily and seems to be of the highest quality. My car was never equipped with a front bar so I did have to do a little bit of "adjustment" to the factory mounts to get everything lined up and moving smoothly. I wasn't able to adjust the drop links or take a test drive since the car is mostly in still pieces. In a few months when I get the car back on the road I'll know how it works....
Matt
'70T
Old 10-21-2006, 08:29 PM
randywebb's Avatar
re the wt. differences mentioned above...
1st - this is not a hugely important location re wt. savings.
2nd - I talked to Tarret via Email on one comparison between his and SRPs bars and the SRP one werre actually lighter. So, if you care, then check each particular configuration - don't just rely on broad claims.
Old 10-22-2006, 12:57 PM
