FinallyGotOne's Avatar
Question i had posted this pic but got no replies... please look and advise
may not be anything at all. But I wanted to check.
by the way here are a couple other shots of the SC
Old 10-23-2006, 07:16 PM
Your car looks great! Of the late model wheels, those are my favorite. I had a black 3.2L car, and at one point considered getting those wheels and painting/coating them gloss black, but I stayed with Fuchs.
Yes, I'd say you've got a couple of pieces of a belt which isn't a problem. I can't say however what the rubber cap thingy is. Is there a chance of getting better pics of that part or maybe a more detailed description?
Old 10-23-2006, 07:25 PM
LakeCleElum's Avatar
You might state your question more clearly to generate replies...No sure what your asking?
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-23-2006, 07:26 PM
I believe before the question was, what are these things and are they important. He said the two parts look like part of a shredded v-belt. I agree. I believe he said that the other part is a rubber cap of some sort. I dunno, maybe the hood shocks when bad and the PO used a rod with a rubber foot to hold the hood up and that foot is from the rod. It's hard to tell because the pics are blurry.
Old 10-23-2006, 07:29 PM
Goth's Avatar
I didn't want to guess, but at least you get a free bump to the top.
Could it be the protection cap in #13 below?
Funny thing is, I've never actually seen one of these on a car. I think they must fall off all the time.
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 10-23-2006, 07:37 PM
slodave's Avatar
Here's my guess:
Dave
Old 10-23-2006, 07:44 PM
Used Up User
imcarthur's Avatar
I'm with Dave. Hood/trunk stopper.
Ian
'87 Carrera Cab
Old 10-23-2006, 07:58 PM
SC Schrauber's Avatar
Ian
No, protection cap.
Frank
81 SC, www.frankschroeter.com
Old 10-23-2006, 08:13 PM
Used Up User
imcarthur's Avatar
The protection cap is just plastic. That has a metal insert with thread(s?) to screw on to something. I'll have a look tomorrow . . .
Ian
'87 Carrera Cab
Old 10-23-2006, 08:49 PM
slodave's Avatar
I started to take one of my rubber stops off, but it is falling apart. I promptly tightened it again.
Dave
Old 10-23-2006, 09:00 PM
slodave's Avatar
Here is a pic of the plastic cap from the pic that Doug scanned.
Dave
Old 10-23-2006, 09:06 PM
Used Up User
imcarthur's Avatar
Not the stops either. They have a built in thread. The rear are rubber & the front are hard plastic but they both have threads. See the fuzzy image below.
Nice car btw . . .
Ian
'87 Carrera Cab
Old 10-24-2006, 05:13 AM
Originally posted by SC Schrauber
No, protection cap.
Frank
It is definitely not the fan nut cap.
Warren & Ron, may you rest in Peace.
Old 10-24-2006, 06:09 AM
Wash. State
nesslar's Avatar
Cool
......radiator height adjustment eccentric bolt access hole plug....
Old 10-24-2006, 07:52 AM
well what seems odd about that little rbber thing is that it has what appears to e a washer seated in the big end. Alos the hole is at the narrow end of it and it wides out a bit toward the end.
Man I gotta bit sideways coming out of my neighborhood! it straightened really easy, reminded me of all those laps at Malibu Go Karts speedway Good thing I have many laps under my belt...
Also this ride goes to 6,000 rpm's really quick in 1st gear. is that pretty normal. Taking a bit of getting used to and all so far. Thanks MASRAUM for the compliment
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 10-24-2006, 08:27 AM
goldgunner's Avatar
What size / diameter are the threads inside that cap?
Where was it found?
Looks to me like it may have been a protective cap that came on an A/C compressor, which would have been then removed and hooked up to either the high or low hose line fitting connectors.
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 10-24-2006, 09:25 AM
GOLDGUNNER there are no threads in it. I found it sitting inside my engine bay. I was looking down inside toward the right of center at a area that appeared to have a bit of oil leaking. I was going to try and clean up the oil but noticed that and the broken v-belt parts. It is not the same shape as my lid bumpers FYI. I tried searching parts through Pelican but could not locate it. Quite the mystery...As far as anything with A/C, Man my A/C works better than my Land cruisers!!
1979 911 SC
Old 10-24-2006, 09:31 AM
goldgunner's Avatar
it could still be a protective cap that should have been discarded - even without threads. If your a/c compressor looks like a replacement, that would still be my bet.
Old 10-24-2006, 09:33 AM
Is that the cap on the right side of the air box ??
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 10-24-2006, 09:35 AM
