brake disc question
What are the best cross drilled brake rotors to buy
Rick T |
Automotive Monomaniac
For looks? For track use? For the shortest stops?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Re: brake disc question
street use and why only buy factory
Rick T |
will the drilled hole units crack under normal streetuse
Rick T |
Yes, there is an aftermarket maker of high quality OEM equivalent rotors, which have the necessary cast-in holes in the correct locations plus the chamfering: Zimmerman...made in Germany. I have had very good luck with them, they last, and I've never had one crack.
Regardless of what Graucho said, proud to be an R Gruppe member |
If zimmerman cast their holes like the OEM wouldn't they be as good. I thought that Porsche AG bought there rotors from zimmerman
Rick T |
Again, for street use it doesn't matter at all
THx - I didn't know P AG had shifted suppliers.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Although stated many times..and repeated often...are factory rotors indeed cast vs others drilled ???
See inconclusive posts here---> Are rotor holes really cast or drilled? - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
love my Brembos!
X/A |
Will you can pick and choose threads that show what you wish to show all day.
930, 993, 996 holes are cast in I posted pictures of the molds, I have the patent document somewhere on my computer. Here's half of one of the masters
Bill,
So I can understand the process: This is half of the pattern to make the center piece of the mold. There are other patterns to make the two outer mold pieces. The outer pieces have the holes in them that align with the half-moon cut-outs in the supporting ribs (vanes) of the center piece. The final mold consists of the inner piece, two outer pieces and the outer mold housing. Once assembled the rotor is cast. In the machining process the holes are left as cast (just like the rest of the interior). Great design. I particularly like the half-moon in the internal ribs. I think the turbulence there adds to the heat transfer. Having the perimeter of the holes supported by the rib reduces the stress at the hole, preventing cracks. I also like the extra little support rib. I’m convinced. These will be my next set of rotors. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Bill:
I wasn't trying to be argumentative.....the referenced thread did not make it expressly clear ( at least not to me!) that a definite conclusion was reached...... Here's a thought...even for those rotors that are "post-mfr-drilled"...would a tedious individual polishing of the hole circumferential surface...be OK to avoid subsequent cracking by removing local stress-risers ??? In addition....I believe having a row of ( say) three holes (vs four holes...with the 4th one coming close to the disc diameter-edge)...might be better to avoid / delay cracking?? Meaning..the last hole is not as close the edge as before ?? - Wil
Machined slots...although statistically better at showing cracks...are not immune from this either. As you can see from the Brembo/GT3 pics...successful slots should be formed with gentle radius edges and bottoms to the cut....not a sharp "U" which would introduce a whole new set of stress risers.
- Wil
