injectors
How, might an injector leak fuel into a cylinder .
and cause smoke on start-up
82 SC
thanks
Old 10-25-2006, 12:52 PM
I dont think that it is fuel that leaks into the chamber, its oil that seeps thru the valve stem bushing (worn out bushings) and gets on the cylinder
carrue529
1987 911 Carrera
S.Wong chip|ElginCams|GT3 oil pump|short gearing|Guard TB-Diff|22/29 Hollow T-Bars|monobloc calipers|Bilstein HD/Sport|Turbo tie rods|Strut brace|CobraMonza II seats|7, 9 Fuchs|Elephant polybronze bearings F/R|Wevo eng mounts|bypass cat pipe|M&K muffler
Old 10-25-2006, 01:17 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Oil will induce blue smoke...not fuel.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 10-25-2006, 01:26 PM
Can't a bad fuel leak induce hydro-lock ??....hope this isn't going too far away from the original question.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-25-2006, 01:33 PM
911mot's Avatar
What colour is the smoke? Black would be fuel, blue for oil.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 10-25-2006, 01:38 PM
Colour,
I'd have gone with blue/oil
Mechanic says with exhaust off, and car on lift
its petrol that leaves the exhaust port though.
I'd not heard or read anywhere, of much in the way of injector problems up till now, at least not on petrols.
have to say not convinced really, as its following a top-end rebuild at same shop,
and using reportedly 'good' but used pistons & barrells.
still, give him the benefit of the doubt for now....
BTW anyone here know who I'm using yet
Nineteen Ninety One 964
Old 10-26-2006, 05:58 AM
I had injector leaks on my 83SC, no smoke but they were leaking.
My mechanic noticed this during a tune up. plugs were wet.
I replaced my injectors and injector 0-ring seals. Very good
thing to replace !
Chuck
Old 10-26-2006, 06:27 AM
Well Theres a new set of Injectors on their way, as it's an 82' car anyway so overdue.
but the wholw reason the car went in to start with was smoke,
so a rebuild looked set,
when it came back ( after Three months) it still smoked copiously
on start-up, though now intermittently,
which is somewhat confusing,
back it went for another go.
all at first pointed to # 3 by a process of eliminatiion
(removing leads) indeed removing exhaust initially confirmed
an amount of fluid present in port, after standing.
He looked at stem seals next via covers, and thinks their OK
and re-examining fluid, in fact thinks its petrol hence that injector,
which is where you lot come in,
and hopefully someones hand shoots into the air,
'Mine did that too'
except you havent'
bugger...
Old 10-26-2006, 06:37 AM
911mot's Avatar
Try this - run the car and then pull the fuel pump fuse or relay and wait for the engine to stall. Now leave it the usual amount of time that it takes to make it smoke again on start up (e.g overnight). Refit fuse/relay in the morning immediately prior to starting and see if it smokes this time. If it smokes again its probably not an CIS problem as it should have had no residual pressure in the system. (It might take a while to start though until the pressure has built up)
1984 3.2 Carrera
Old 10-28-2006, 08:42 AM
Interesting,
does this mean (bear with me here)
That in some way fuel is being delivered between key being in ignition?
Old 10-28-2006, 08:45 AM
LakeCleElum's Avatar
On a CIS car, it's pretty easy to pull the injectors, and see if they are leaking.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-28-2006, 08:55 AM
911mot's Avatar
Sort of.
When you switch the ignition off the pump stops running but pressure is maintained in the system. It sounds to me something somewhere is allowing the fuel to dribble through to the injector.
The SC injectors are different to the 3.2 - the 3.2 injectors are opened and closed electrically with a multiplug on each injector. On the 3.2 its possible to have an injector leak by not closing fully.
I'm not sure how the SC delivers the fuel to the injector but they all inject at once. So if one was leaking I would expect the others too as well? Maybe a CIS guru can help here, I'm better with EFI.
1984 3.2 Carrera
smoke though?
I'm clutching at straws in an effort tofollow his thinking really.
perhaps I'm wrong here, and would loved to be proved wrong,
but blue smoke (which is what i'd call it)
is widely reported as an oil issue
Old 10-28-2006, 09:05 AM
911mot's Avatar
Is the problem on just the one cylinder?
Has a compression test been done?
Does the smoking stop when you disconnect #3 lead??
1984 3.2 Carrera
Old 10-28-2006, 09:11 AM
perhaps I should explain in outline;
had a top end carried out same place
head, guides, seals & used but reportedly perfect pistons+ barrells.
had it back after work carried out, but smoked (biggg puff) occasionally on starting
hot or cold AM or PM made no odds parked on flat BTW
took it back where it had a compression test
(broken ring on rebuild possibly)
nothing in it to indicate a good starting point
so in order to check car with engine still in it,
removed leads one by one over several days, and thought #3 seemed culrpit.
he popped off the exhaust with it on a lift, and
again started it looking for squirt of oil from exhaust port
instead found it to be petrol.
removed covers and says the stem seals all look in order
and coincidentally marked pulley at start to find it only smoked on starting in 1of6 rest positions
Old 10-28-2006, 09:21 AM
Every so often my 88 smokes on startup, actually a small cloud. I was told it was due to the cylinder walls being horizontal oil would seep past the rings into the chamber.
Old 10-28-2006, 09:34 AM
Somatic Negative Optimist
Gunter's Avatar
Sounds to me a compression and leak-down test is in order to get the real picture.
CIS system has residual pressure left after ignition is turned off but even a leaking injector (Or leaking Cold Start Valve) should not have an excessive discharge.
Besides, a leaking injector would give you bad idling.
CIS-Injectors can be easily checked for leaks and new ones are relatively inexpensive.
You mention a rebuild but may have some doubts?
Go to a DIFFERENT shop for the Compression/Leak-down test IN WRITING.
Then let us know.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Gunter
YHM
Old 10-29-2006, 12:01 PM
