Question How to verify BOV is working properly?
Hi,
I have one of the GSF BOV that vents to atmosphere (I'm running EFI).
I'd like to understand how do I know it is working properly in the sense that -
a) It is venting sufficiently,
b) It is venting at the right time.
I really don't like the sound but I can hear that it opens even when I lift from cruise speed (i.e. from no boost to close throttle). Is this normal / desirable?
The unit is said to be adjustable. But how to determine what to adjust it to?
thanks.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 10-26-2006, 02:26 AM
greglepore's Avatar
http://www.gofastbits.com.au/index.php?parentid=tech_info&option=tech_info
Good discussion of BOV's.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 10-26-2006, 04:19 AM
Thanks for the link Greg.
It confirmed my thinking of how BOV works and seems to say that the fluttering sound I hear, particularly loud at cruise->close throttle situation, is an indication that mine is set too tigghtly.
I'll try to loosen it a bit & see if it changes anything then.
Any idea about how to set the BOV spring properly?
Old 10-26-2006, 06:10 AM
greglepore's Avatar
No, sorry. My experience has been with non adjusable bov's where you have a fixed spring that matches the wastegate-but I believe that you want the bov setting and the wastegate setting to match. When the valve opens, it makes a "phssss" sound, loud and brief, not a flutter.
Greg Lepore
85 Targa
Old 10-26-2006, 07:02 AM
Halfway down the first page of this thread Tsuter describes in detail the operation of a BOV. There is no matching of BOV to Wastegate.
Turbo guys - Question about BOV's.
Warren & Ron, may you rest in Peace.
Old 10-26-2006, 07:46 AM
Send a message via AIM to fierochris Send a message via Yahoo to fierochris
its not good if you can hear it when its not under load. that means its leaking boost before it enters the intake. your spring is too loose not too tight. it shouldnt be venting till you shift, or let of the throttle.
BTW, venting into the atomispher does not give you any performance gains. just the neat sound. and a little insurance
71' 911T Targa, current toy.
86.5 928s traded for new 911
71 911 Targa w/ gas burners, PMO's, *sold*
Lamborghini diablo replica w/ 350 V8
85.5' 944 n/a euro ( gave to dad )
87 fiero cp. candy blue, chrome 16's
90' DSM 24psi. 18G fmic,
82' benz 300sd turbo, intercooled.
73' Karmann Ghia cab. sold
04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs,
check out www.vintagevwcars.com
wanted: 914, 944, 928 project
Old 10-26-2006, 04:57 PM
930turbo's Avatar
I agree, the spring tension is too loose. This allows the valve to open under light manifold vacuum. Another symptom of low spring tension is, after a hard charge and when the throttle is initially closed, the boost/power drops off abruptly and can actually upset the balance of the car if your cornering. Be careful.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 10-26-2006, 05:12 PM
I hear it only when I shift or lift (ie closed throttle).
I thought its normal as there is pressure differential (very low under throttle plate & "atmospheric" above) when I lift. According to the the GoFastBit site, the sound means the air is venting back to the turbo - so bad.
Did I mis understand?
Old 10-26-2006, 05:13 PM
That seems exactly what I'm experiencing - when I lift/slow down my acceleration even @ 4000 RPM, my boost would instantly disappear pretty much completely.
Guess I need to increase tension on the BOV spring then?
I'm confused
Old 10-26-2006, 05:17 PM
greglepore's Avatar
Any time the pressure differential exceeds the spring pressure, it opens-it shouldn't open on a slight lift where the car is still "on the throttle" but feathered, but should open instantly on a full lift .
The only time the valve should open is a rapid throttle close under boost; if its opening under low/no boost throttle closure, then its not tight enough.
Greg Lepore
85 Targa
Old 10-26-2006, 06:39 PM
To be sure, this is my situation:
I'll hear a loud fluttering sound (assume its BOV opens) when:
a) I lift off throttle (for upshift or simply let off the gas pedal) from any speed including say cruising at 40mph
b) If I accelerate (say for on ramp) then have a momentary hessitation in pressing the gas pedal, my boost will instantly disappear
Based on these, I think the BOV is too loose?
Old 10-26-2006, 07:04 PM
