High pitched AFM whine
Ok guys...a bit of a panic here. Yesterday I removed the AFM on my '88 3.2 to get access to try and fix some oil leaks (no go on that) and then gave up and put everthing back. Now I get a very high pitched whine from the AFM except when I tap on the accelerator. Any ideas?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-30-2006, 06:07 AM
Bump to get the afternoon crowd. I'm wondering if I should risk driving it home....it seemed to be running exactly as before, just a loud whistle/whine when no load. The instant I touch the gas pedal it goes away until engine no longer under load.
TIA
Buck
'88 Coupe, '87 Cab,
Old 10-30-2006, 01:13 PM
heiliges blechle!
My '84 gets a high whine this time of year when the engine is cold. It is from the Ambient Air Valve. It goes away when I step on the gas a bit and then after the car is warmed up. In the summer you never hear it. Must be an air bleed somewhere otherwise.
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 10-30-2006, 01:22 PM
Might want to pull your AFM again and see what hose you missed.
Old 10-30-2006, 01:47 PM
OK, I found one of the cloth vacuum lines that goes from the back of the throttle body over to the group of connections by the oil filter connection. Hopefully that's what was causing the whistle/whine. It seems like a likely solution.
Thanks for the help.
Buck
'88 Coupe, '87 Cab,
Old 10-30-2006, 07:29 PM
