sal sal is offline
Sal
sal's Avatar
Not all oil filter are created EQUAL!
I recently had an oil change due on my SC but had no filter, so I went to Pep boys and found a Percolator filter and decided to use it for this oil change. I thought all oil filter should be about equal. I also decided to go ahead and buy an extra one just in case. I ended up using them on two oil changes. What I noticed was the the amount of very fine metallic shavings on the magnetic oil plug. Since then I have bought and used Mahle oil filters and I was surprised that the magnetic oil plug had no metal shavings at all. I imagine that the Mahle did a better job. Its Mahle from here forward!
Old 10-31-2006, 11:08 PM
Autobahn Garage
put a Puralator in one hand and a Malhe in the other, you can feel the differance in weight. The Malhe is much heavier
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 11-01-2006, 03:11 AM
Over the years there has been much said about the internal check / backflow valves, etc....flow path, spring loaded "end-valve", etc, etc...that may be missing on the aftermarket units ...
Go w/ Mahle.....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-01-2006, 04:24 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
+1 for Mahle
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 11-01-2006, 04:36 AM
Bill Verburg's Avatar
Go w/ Mahle.....
- Wil
The old red Purolator 260s had the internal check valve and were everybit as good as the Mahles of the day.
The new white Purolators are crap, there isn't much inside of them.
I bought one just to see what was in there
Bill Verburg
Old 11-01-2006, 04:48 AM
In a recent post on another thread, somebody said that Mobil 1 filters are excellent. I'd always assumed they were simply a marketing exercise--an ordinary Fram or Purolator or whatever filter with "Mobil 1" emblazoned on it. I'm still not convinced...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 11-01-2006, 04:53 AM
Bill is Dead.
cashflyer's Avatar
Here is a pretty good site that compares several different manufacturers. It also explains certain "tell-tale" characteristics that can help you identify the real manufacturer of private label filters.
http://minimopar.knizefamily.net/oilfilterstudy.html
Old 11-01-2006, 05:08 AM
There is only one thing you need to know, Mahle
Bill Verburg
Old 11-01-2006, 05:14 AM
That minimopar site is fascinating. Summarizing it in way too few words, it basically says that the Mobil 1 filters _are_ substantially better, that they're manufactured by a company called Champion (not the sparkplug people), and that Mahles are very similar, perhaps even identical, in deisgn and construction to Champion filters, drainback valve and all.
Oh, and that the world's worst oil filters are anything made by Fram.
Stephan Wilkinson
Old 11-01-2006, 05:23 AM
Why is that? Do you have evidence to back up your claim?
Warren & Ron, may you rest in Peace.
Old 11-01-2006, 05:44 AM
charleskieffner's Avatar
oh no we here we GO AGAIN! and its only wednesday! LOL! would be interesting test between MAHLE and MOBIL 1 filters.
Old 11-01-2006, 05:47 AM
If you read more than simply the last post in line, you'll better understand what's being said.
I said I was summarizing what the very interesting, thorough and detailed minimopar site says, not my opinion. If you go there, you'll see a certain amount of evidence. Up to you whether or not you want to accept it.
Stephan Wilkinson
Old 11-01-2006, 06:23 AM
IROC's Avatar
There was a guy about 10-12 years ago on the old porschephiles mailing list that had his 944 engine taken out by a Fram filter. He got into it with Fram and in the end he proved that it was the filter that blew the engine and Fram paid for a rebuild.
That's the only story I know of first hand, but I have heard there are many more...
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-01-2006, 06:25 AM
Fair enough Steve.
Mike, I've heard those stories as well...some related by mechanics. However, an explanation was given that seems plausible as well. I posted on it previously....
"In talking to a Mann engineer I was told that the Fram single-pass efficiency percentages were amongst the best in the industry. He had no comment on the ruptured canisters though."
From Fram regarding filter failure: http://www.fram.com/pdf/OverPressurized.pdf
I have no reason to defend Fram other than to look at the popular beliefs and try to understand the root cause of failure.
Old 11-01-2006, 06:53 AM
rough cost on mobil 1 filter is $14 bucks. mahle about $7.95 they blow frams out all day at $2.99-$3.99.
i say we cut a mahle at 3000 miles and a mobil 1 at 3000 miles and see whats up?
Old 11-01-2006, 06:58 AM
If you spend some time reading sites dissecting Fram filters, you will see that they are consistently of poor construction. The only filter they made that is worth a damn is the HP-1, and that is because it's the old standby for all of the racing world and is indeed of better construction than the rest.
I recently changed my filter and purchased a Napa Gold at my local FLAPS and weighed it - came in at 523 grams, much more than a mahle or mann for that matter. The construction was second to none. Would use it again in a heartbeat. The Mobil 1 filters for 964 and later 911s are on nationwide backorder.
K&N also makes a wonderful filter, but I would say it's not as good as the Mobil 1 when it comes to filtration. I would say that the K&N probably has the highest burst strength.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 11-01-2006, 07:00 AM
Yes, the minimopar site says that good as they are, Mobil1 filters aren't worth the money, since they're no better than other Champion-made filters that cost substantially less.
Mobil 1 is a huge marketing thing, good as the oil is. They now have "extended-life oil," "SUV and truck oil" and I believe "four-cylinder oil." Pretty soon they'll have "variable-valve-timing oil" and "cars equipped with nav systems oil"... And filters, and Mobil 1 dipstick rags and drainpans.
Stephan Wilkinson
Old 11-01-2006, 07:02 AM
LOL, I agree on the rebadging of oils. I tested various formulations of the same weight and they are the same, just marketed to European Cars or Truck and SUV and same with the "Extended Life" which I found no different from the tri-synthetic from last decade and their more recent super-syn.
Charles Navarro
Old 11-01-2006, 07:07 AM
see alot of k&n's on off road race vehicles due to safety wire option. have seen a fram burst on 350 chevy and puke motor. owner stated it was frams fault and bellied wife up to fight fram. needless to say wife dumped duties back on him, and nothing ever came of it.
have used napa golds and they seem to be good. but i am anal when it comes to 3000 mile oil changes or if i take 911 to track. the day after track...........out goes 11 quarts dirty oil and in goes 11 quarts clean oil and new mahle.
my question..........is a mobil 1 filter worth $7 bucks more????
My personal opinion is yes on the M1 filter (if you can get them - I couldn't just recently for my 91), considering how much time it takes to do an oil change and how much the oil that goes into the engine costs, especially if synthetic.
Charles Navarro
Old 11-01-2006, 07:32 AM
