Leland Pate
Guest
Posts: n/a
Why do turn signals blink faster when cold?
This is one of those questions that I have been meaning to ask for about 8 months now and just now remembered to ask while I am on line.
When it is cold(er) outside my turn signals flash much faster than normal.
This isn't too huge of a problem but whenever I sit at a red light and some dude is in front of me and his signal is flickering more rapidly than most others it kinda bugs me a bit.
Why would turn signals flash, flicker, pulse, whatever faster?
Any ideas? anyone elses do this?
Leland Pate
___79 SC Targa
Old 08-15-2000, 12:34 PM
BlueSkyJaunte
Guest
Posts: n/a
Superconductivity!
(someone had to say it--now back to your regularly scheduled post)
Just speculation, but could it be the switch? If I don't engage my signal lever fully into the detent, my turn signal flashes faster. Perhaps the cold causes plastic in the switch to shrink, and as a result the contact in the switch is a bit iffy. Well, that's my guess, anyway.
What's the frequency difference between "cold signalling" and "warm signalling"? Does it change as the car warms up?
bleeeyoo
Old 08-15-2000, 01:02 PM
Mully
Guest
Posts: n/a
The signal blinker is a bi-metal switch
When dc current passes thru it the two pieces
of metal heat and seperate causing an open lamp circuit.When the metal cools the switch closes causing a closed circuit and your lamp turns on again.Cold weather accelerates this
process.
Old 08-15-2000, 01:05 PM
Early_S_Man
Guest
Posts: n/a
Most electronic components have less resistance when cold, so operation is faster because the RC time constant is lower when the resistance is lower. I believe the newer Porsche flasher relays have not used the bi-metallic elements in about 30 years.
Warren Hall
1973 911S Targa
Old 08-15-2000, 01:26 PM
Superman
Guest
Posts: n/a
Superconductivity. (I wanted to say this too).
Actually electricity does travel better along a colder conductor than a warm one. Probably not enough to make much difference.
'83 SC
Old 08-15-2000, 01:36 PM
Leland Pate
Guest
Posts: n/a
Well thank christ it wasn't an easy question to answer anyway.
Oh well as long as no one writes back and says that fast turn signals are a bad sign of complete Porsche meltdown: (where the car literally melts into goop"
I guess I'll just live with it. Thanks,
Leland Pate
___79 SC Targa
Old 08-15-2000, 02:36 PM
