THE IRONMAN
stub axle nut removal !"/$%?&*
OK...any hint to remove the stub axle nut. I am in the process to do a job on my axle shaft CV joints...and unable to remove that !"/$%?&* stub axle nut. Advice is welcome...Thanks...Syl
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Heat is your friend.
you need a hugely long pole to put over the end of the breaker bar. I think those things are 300 or 450ftlbs.
THE IRONMAN
Yea...I will...And I need to find a stronger holding bar...as you can see on the pic...the one I use start to bend...there's any problem to use heat on the axle nut...because the axle will be heated too...!
Impact Wrench. <10s job. If you dont currently own one, buy the biggest lb-ft you can find for exactly these types of situations. (I've got an older ingersoll rand 2130 w/ ~600lb-ft of removal torque - the newer 2135 hits 1000lb-ft). Stay away from low-end home depot/craftsman/etc (though sears does sell some IR tools)
If you don't want to buy anything, use the bar, set the e-brake, AND have a friend mash the brake pedal while you try. Then go buy a big impact wrench when that doesn't work ![]() SMD
Stephen 70 914/6, GT clone, 3.0L 83 911SC, IROC clone, 3.32L, EFI 84 930, 3.5L |
leverage is your friend...I got a 4' black pipe and put that over the breaker bar.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Tabernac... if it is drivable, go to a local garage with an impact wrench and have them break it loose. Then tighten it up with YOUR wrench so you know you can loosen when you get home.
Tony G 2000 Boxster S |
Somatic Negative Optimist
Syl:
Stop the butchery! You'll damage the studs and might knock the car off the stands! Look at the manual, that nut is tightened to 220 ft-lb meaning: Unless you have a 3/4"drive impact, you'll need a 3/4"drive socket, short extension, 3/4"breaker bar with a 3-4 ft pipe-extension. Now take the center caps out of the rear wheels, mount the wheels, lower the car onto the wheels, put it in reverse gear, apply the hand break, use the socket thru the center hole of the wheels, short extension, breaker bar with pipe extension and step on it (Use your body weight) The nut will come loose. It's all about fulcrum and leverage and 3/4" stuff, NOT 1/2 inch! I don't recommend heat, but make sure the cotter pin is out. A search here BEFORE the attempt would have helped; it's been covered many times.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Isn't that nut supposed to be tightened and loosened with the weight of the car on the wheels?
gunter's got it.
Hell Belcho
What I did...
1. pop out center cap 2. carefully heat up nut 3. Had friend press the brakes, e-brake on, tire on ground 4. 4 foot long breaker bar still took some effort to get it loose
Saved by the buoyancy of citrus. |
I actually BROKE a 1/2" breaker bar before I got a 3/4" one which was up to the task.
another vote for a decent impact gun.
*NEW 1969 911t targa soft window option 1967 912 Targa Soft Window 1989 911 GP White Cabriolet 1970 911t 2001 Chevy Silverado 1500 1997 Audi A4 Quattro 2.8 2003 Acura TL Type S 1973 911t 3.0 track car (SOLD) |
THE IRONMAN
Many thanks Gunter, I borrowed a heavy impact from a friend and will try it tonight...if the nut resist...I will go with the 3/4 stuff and a long bar with the car on its wheels. I will let you know the results...Thanks every ones.
![]() I ran into this same problem on my car. Bought a better impact (craftsman) that did the job. Put it back on with the impact too then drove to my local wrench who had to BARELY snug it up with thier huge torqe wrench. Nice. -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Harbour Freight has a 1" metric set for around $35.00. I worked on my 87 carrera which is torqued to over 350 ft. lbs.
Keith Epperly 87 slant nose turbo look carrera cabriolet |
THE IRONMAN
I am well equiped with torque wrench...I am an Aircraft Engineer and the company I work for got a lot of them...along with some impact...He...He...He...
You do not have permissi
For the serious torque specs: http://www2.northerntool.com/product/200315001_200315001.htm
Meanwhile other things are still happening. |
