slammed1000's Avatar
Send a message via Yahoo to slammed1000
3.6 wiring/dme questions
i am wiring my1990 3.6 into my early car and have a question to those that have done it. i am following steve timmons wiring diagram but i do not see a color on his chart and i know it was hooked up. the engine was installed in a sc and i know it was hooked up before. out my harness i have these colors red,green,black(looks dark blue) yellow. the yellow is the one in question. per steves directions the red is 12v to battery, the green is to the fuel pump,black is 12v switched,violet is the tach,brown gets grounded at the relay and ther is another blue and white wiring i am not to sure about either. there is no yellow wire in his conversion harness diagram. it appears to be hooked up to a 12v source before as it had a fuse inline. can anyone chim in on this as i would like to try and start the car today.......if anyone needs pictures i will go out and snap a few to show......thanks, brent
Old 11-08-2006, 07:34 AM
bump
Old 11-08-2006, 10:57 AM
where can you be reached. i can help you out.
bhoward@wlgore.com
2016 GT4
Old 11-08-2006, 11:21 AM
I seem to recall the yellow is the output to the fuel pump.I can,t find my original notes on my install though to check the blue /white or yellow.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 11-08-2006, 03:59 PM
