audi2.7t's Avatar
O2 sensor ?
I just noticed that my O2 sensor is disconnected at the plug in the engine compartment. I have a test pipe with Bursch muffler that were recently installed along with a new sensor (P.O. had work done at an engine shop). Does it make any difference if it's connected or not?. When the engine is stone cold it takes a little bit of throttle modulation to get it to start and idle (about 10 seconds) and I was wondering if this had anything to do with it?.
Thanks.
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 11-22-2006, 03:28 PM
we'll see if others chime in...my car runs fine with O2 out...I did this to put a wide band reader to check the WOT AFR...while on the on WOT map the AFR was fine
Sold: 1989 3.2 coupe, 112k miles
Old 11-22-2006, 03:43 PM
while not on the WOT map..the AFR was fine...
Old 11-22-2006, 03:44 PM
Connecting the 02 sensor will not make any difference with your starting difficulties since it needs to warm up and that may take up to 5 mins. before it functions.
Old 11-22-2006, 04:15 PM
