CIS pressure testing
I'm working on a 78 SC CIS system. I have a few questions.
First the symptoms that brought me to want to mess with it are these. Starts o.k. but right after start up it runs rough, popping stalling. After warm up runs good. So form these symptoms it seems (from the Bosch book) to be a good place to get some info on system pressure during warm up. Hopefully it will give me some insight into what the pressure control regualtor and auxiliary pressure controls are doing during this time. Question #1: The manual says to pull the fuel pump relay and hot wire it so you can flick it on and off with a switch while your working back there. a) After studying the wiring diagram and playing around with the relay socket I can't get it to behave as I would expect. Shouldn't there be a lead that is always hot going to one post on the relay? This would be the high current contact that the pump is connected to when the relay flips? Non of the relay contacts at the socket have 12v when the ign switch is off. So what do I jumper to make it go? b) Isn't the whole point of the jumper that you can run the pump with out heating the elements in the other fuel system controls. Based on the wiring diagram this isn't possible by just jumping relay contacts because the wires for the heatign elements nad the pump are joined behind the panel. So when you hot wire the pump your also hot wiring the heating element and thus defeating the whole purpose becasue as they heat up the system will change the pressure. Question #2: There is a connector that goes to a littel blue piece on the back of the housing that holds the up draft flapper. It has been disconnected. When I connected it the motor ran worse. I don't see any reference to it in any manual. Now remember this is a 78 ( black K distributor). It doesn't fancy stuff like KE. There shouldn't be any electronic correction devices on the back of the fuel dist area. Here's the other weird part. It doesn't look like much other than a little plug that is screwed to the housing. All I can imagine is that there is a little thermo resistor inside that is giving some temp signal back to something. But if that was it why would it be mounted on the aluminum housing at the flapper valve???? ambient air temp correction? Again no reference to this any where. So in summary ( holly crap this is a long description) how have others done the fuel pump hot wire? What is the point over just turning the key on if the heaters get voltage anyway. WTF is the little blue connector on the back of the flapper housing? Can anybody save me the time of all this and give me another diagnosis idea for the warm up sysmptoms? P.S. I did a good visual inspection in teh beginnign and don't see any cracked vacuum connections or other visual wear/damage. Thanks, Adam
1973 911 T Targa |
U can pull the connectors off of the WUR and aux air reg if u dont want them to heat up.
is the connector u are talking about behind the air flow meter? if it is, i THINK it is there to shut off the fuel pump if the engine is not running...if the engine stops, the plate drops to resting position and shuts off pump for safety reasons...dont hold me to that. look at your wiring diag, you will see it coming off the FP RLY. why it is affecting the way it runs baffles me, cis is not controlled by any electrics other than the cold start valve.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Somatic Negative Optimist
Adam: What manual are you using? Just the Bosch? The Bentley tells you how to jumper the fuel pump on 240-11 and yes, ignition is on for the tests.
The Bentley also gives you the right terminology: Your "Draft flapper" is the air sensor plate and the switch connected to it is the "Air Flow Sensor Contact" and needs to be connected. Also, even though you don't have Lambda, a '78 has K-Jetronic CIS and is subject to the correct wiring, especially for WUR, AAR, CSV. Get the Bentley SC Repair Manual and study it to learn more about CIS and follow the wiring schematic. Check that the wiring is correct and then perform a pressure test according to the Bentley. It sounds to me that your WUR and/or AAR is not performing right. The Bosch manual is general about CIS but the Bentley is specific for your SC.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() |
There is a Bentley in the back of the car. I also have the CIS book Pennington wrote on how to trouble shoot CIS if you want me to email the PDF.
Thanks for helping me with this. Andrew
(6) cars currently in my garage:1976 Porsche 912E #627 Ascot Green 1986 Ferrari Mondial 3.2 Coupe Brown/Tan 1986 Porsche 911 Carrera 3.2 Paint to Sample Brown/Brown 1985 RoW Mercedes 420SEC C126 Coupe Brown/Tan, 1978 Alfetta GTV with a TwinSpark, 1997 BMW Z3 1.9 Boston Green/Beige 5speed |
Designer King
The blue item is the cold start injector and its connection. The nearby green one is for the shutoff switch that T77911S mentioned.
If you search the archives you will find more info on this system than you thought possible. Jim Williams (I think) has a site w/ a very good explanation of he system and its components. You should also get the Bentley manual as Gunter said. You are on the right track. Control pressures are critical for proper system operation. Sounds like your WUR is out of adjustment, especially during the warmup phase. There are articles here on how to adjust it and to make it easily adjustable. Your AAR may also be not functioning correctly. Member Mystery Train has a writeup on the AAR that shows how to adjust. The Bentley has charts showing control pressure ranges. If you post what you get, we can tell you if you are in range. Let us know the ambient temp @ startup.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Thanks guys. I'll post more info as I continue to dig into it.
Adam,
1973 911 T Targa |
Some answers to your questions....
Adam,
Some pointers: #1-A). Connect terminals 87A and 30 of the fuel relay using a jumper; and turn the ignition switch on. With the ignition at off position, there is no 'power' going to terminal 87a. #1-B). The objective of jumping 87A & 30 is to test run the fuel pump without the engine running and subsequently be able to measure the control and system fuel pressure (cold stage). For cold start, you want low control pressure reading and high system (delivery) pressure. TD |
TD,
This is what is confusing me. The pump normally works without the motor running. Just turn the key to the on position. So if you are turning the key on to get the jumper to work how is the jumper doing anything different than the relay? I guess the only thing it does is let you have a swith in your hand instead of reaching in and turning the key. Is that it? I thought we were doing it to avoid powering other systems that are switched by the ignition key.
1973 911 T Targa |
I know that on most CIS cars, the fuel pump relay powers the pump for several seconds, but then switches it off if there is no RPM signal (indicating that the engine has started).
It's a safety feature. The purpose of the jumper is to bypass that feature and let the pump run longer/continuously for testing. |
Ah ha! Thank You.
1973 911 T Targa |
Some confusion....
Adam,
Now I realize where we get confused. You have a '78 SC with CIS system installed in your '73 car. The information I posted earlier was for SC CIS systems. If you can make the fuel pump run by just turning the ignition switch on, then you don't need to connect terminals 87A & 30 to test run your fuel pump. But what also confused me is that you don't get power on any of the fuel pump relay terminals and yet you claim that the pump is running when the ignition switch is turned ON. This does not make sense at all!!! So why do you need a jumper set-up to run your fuel pump? Now I am really confused too. TD |
Adam is being a great friend and helping me with my SC. I have limited (well Zero) skills and was getting sick over all the money I had to poor into mechanics bank accounts and STILL ended up with a car that was not running right. Adam stepped up to the plate and offered to help me with my car. It's a 78 RoW SC he is working on not a late engine in his 73. Thanks to all who have contributed in helping Adam help me.
Andrew
Now Let's Go to basic.....
Adam / Andrew,
First in a normal set-up, the fuel pump in SC car will not run or operate with ignition switch at ON position only. Unless the alternator rotates (driven by the engine), the fuel pump will not deliver fuel. This is a safety feature. However, you could circumvent this safety feature by using a jumper for terminals 87A & 30 or lifting the sensor plate to energize the fuel pump. After re-reading your post (Adam's) several times, I will concur with Dr. Gunter's suggestion regarding your WUR and AAR. So hooking up a CIS fuel gauge will give you the control and system pressure (cold stage). You can start with this finding. Jumping terminals 87A & 30 will not energize the WUR, AAR, nor the CSV. Please someone correct me if I'm wrong because I want to learn too. Thanks. TD |
I'm just starting to figure CIS out, so experts can correct me if I'm wrong, but from what I've read the WUR and AAR get power from the alternator (i.e., car must be running). CSV gets power only when the starter is engaged.
All above applies to 78 SC.
Kirk J. 78 SC euro |
Not quite, guys. The alternator doesn't play a role in this, though of course it only does something when the engine is running. The alternator is always connected directly to the battery, and from the same post that comes from the battery (via the starter, but always connected because on the same connection post) is the not quite so big red wire that heads from the alternator over to the relay/fuse panel in the engine compartment.
The fuel pump is controlled for safety purposes by a switch actuated by the air flow measuring plate (or whatever you want to call it). When that plate moves up it breaks a contact, which allows the fuel pump relay to actuate when the ignition switch is in the run position. That's why pushing up on the plate will cause the fuel pump to come on in the run ignition position. But when the ignition switch is in the start position, this interlock is bypassed and the fuel pump runs no matter what the plate and its switch are up to. There is one odd thing about this interlock. I think that the NC position of the fuel pump relay is the one that powers the fuel pump from the switched ignition source. But when the interlock switch is closed, this powers the relay (which gets its ground via the interlock switch), moving the relay contact to the NO position, where it gets its current from the starter control circuit. Once the air flows through the system the interlock switch opens, the relay relaxes, and power flows to the fuel pump from the ignition switch until either it is turned off, or the interlock closes due to the engine stalling or whatnot. One reason I am pretty sure I have doped this one out properly is this: if I pull the plug from the interlock off, and turn on the key, the fuel pump will run. This can be easier than figuring out how to bypass things with a piece of wire stuck between the proper contacts on a dummy relay up front if you want to test the fuel pump. Especially if you don't want to lift the air plate, which will spray fuel out of the injectors. The CSV indeed gets its current via the starter circuitry (if the thermo time switch allows it a ground), because it is neither needed nor wanted at any other time. I had to look up the rest to be sure I remembered it correctly: The WUR (aka control pressure regulator), the aux air slide, and also something I don't recognize called the "temperature valve" (all of which I believe are "heaters" for bimetalic strips) are powered by the "output" of the fuel pump relay. Which means no juice to them unless the fuel pump is running (or should be, if it is working), but conversely they should always powered when the engine is running (or the starter is engaged, for that matter). Dunno how this relates to the initial issue, though. But one hopes knowledge is power. Walt |
Thanks Walt! Appreciate the knowledge.
![]() Quote:
O.K. Adam is helping out Andrew by looking at his '78 SC. Good intentions but............ What concerns me is that , with all respect, Adam doesn't really know his way around the '78 CIS. When he asks WTF is the blue "thingy" in the back of the TB, and "Draft flapper" I have to say hmmmmm............ The sensors (Blue and green) have to be connected! In your case, Andrew, I would check the AAR by taking it out and applying 12 V to it. When cold, the halfmoon is open. With 12V applied, it closes after a few minutes. Next, jumper the pump and check the fuel system pressure. If the WUR is suspect, check the control pressure according to the Bentley. But, before anything, look at the wiring schematic and check the wiring from the starter solenoid to the timer for the Cold Start Valve (CSV) Then make sure that the connector to the CSV has not been mixed up with the connection to the WUR. They have the same kind of plug and they have been mixed up in the past. In Engineering, we trouble-shoot by elimination, i.e. find out what components in the system work. Andrew, I suggest that you find someone who really knows the CIS for the SC's. Bad advise is worse than no advise. Adam is well-meaning but, going around in circles and guessing isn't going to do it. It took me more than a year, and a couple engine rebuilds to have a good basic understanding of a Porsche engine. The learning process never stops. Adam, I hope you're not offended by me speaking bluntly; the best help you can offer is to help Andrew to find someone with more expertise. Friendly greetings. ![]()
walt,
good expianation. the thermo time valve (not SWITCH which is part of the CSV) is connected to the vacuum line between the WUR and throttle body. it too has 12v applied. when COLD the valve opens and vents the WUR to atmosphere but blocks off the vacuum from the throttle body. when WARM, after about 30sec, it connects the WUR to the throttle body. its amazing what u can figure out with a 9v batt and a vacuum tester. the connections are important, the bottom one goes to the WUR, middle to throttle body. when the ign. key is first turned on, the FP will run for 5sec then shut off until the motor is cranked and the "plate" lifts off its resting point allowing the FP to run again. power to the WUR, AAR and thermo valve(if u have one) all come from the same source as the FP...the FP relay.
We'll Gunter that's allot of input! At first I was just going to let your criticism go but you went on long enough that I'm to entised to not respond
I'll do it in pieces so you don't miss anything. --------- Good intentions but............ What concerns me is that , with all respect, Adam doesn't really know his way around the '78 CIS. ------- TRUE! not yet! --------- When he asks WTF is the blue "thingy" in the back of the TB, and "Draft flapper" I have to say hmmmmm............ --------- My original post was after I referenced a generic Bosch book. It didn't mention the "draft flapper" switch or have it in any pictures. Overall I figured I would ask a few questions here to the "friendly" Pelican community before I went on looking at other resources. "draft flapper" Come on I didn't have the book in front of me and didn't want to go look it up. "draft flapper" " draft flapper" "draft flapper" Come on it sounds cute. ---------------- In Engineering, we trouble-shoot by elimination, i.e. find out what components in the system work. -------------- Bachelors and Masters in Mechancial Engineering. Curently run a testing lab that develops Ion Implant equipment. Built entire EFI system for my 73 from scratch. Including designing a high flow air box (made form fiberglass), machined CIS intake runners to take electronic 18lb injectors, made stainless steel fuel rails and plumbing, and the control system. Wrote code in Dynamic C and used a robotics control board as brain. ----------------- Andrew, I suggest that you find someone who really knows the CIS for the SC's. Bad advise is worse than no advise. Adam is well-meaning but, going around in circles and guessing isn't going to do it. ----------------- I'm not really sure that looking at the system for 30 minutes and asking a few quick questions about a wiring schematic and a blue sensor not in my book is really going around in circles. Dont' worry if I end up going around in circles you'll know because going in circles makes me nautious. I'll send you a picture when it happens. ------ It took me more than a year, and a couple engine rebuilds to have a good basic understanding of a Porsche engine. -------- I don't mean to return the negative attitude but "It took more than a year to understand how a Porsche engine works"??? Dude glass houses and throwing rocks! Not rocket science! --------------- The learning process never stops. Adam, I hope you're not offended by me speaking bluntly; the best help you can offer is to help Andrew to find someone with more expertise. ------- Ayway I'm really not that mad just having fun since you started it. I'm rubber and your glue. But seriously I thought I would have some fun learning from you guys instead of just reading books. Not as rewarding as I thought so far! Very rarely have books made fun of me. Actually the only time is when I read " I'm o.k. but you have allot of problems to solve" I found the author to be kinda arrogant. As you guys can tell I'm taking it slow and asking allot of questions to make sure I don't make mistakes and learn as much as I can. I'm also doing this for selfish reasons not just to help Andrew. I know EFI and have rebuilt my share of Webers too so CIS was the next fuel system to check off from the learning list. This is my first chance to get to learn about CIS and I am excited to do it. I knew it was a very simple system in operation and part count. Not very intimidating. I just want to pull on the experiences that others have had and enjoy the conversation. I like the community part of car stuff. It's one of the reasons I do it. So don't worry Andrew is in good hands. It will just be a faster and more rewarding process if you want to share info and things that you have learned. BTW I'm not claiming that I won't make mistakes. I've had a llot of awesome hospital visits and have actually used a fire extinguisher in distress. Wahooooooo! Good story- Once I was flushing out an EFI fuel Inj system with Xylene acid. I was rushing and changed the plumbing real quick becasue I didn't want the regulator bypass to go where it was going. In doing it quick without thinking about it I made it so the system ran at full pump ressure (100psi). Inejector blew off and sprayed me in the face with 100 psi Xylene. Took the doctors 20 minutes with suction cups on my eyes flushing saline to get all the acid out. No sight damage. Actually I should have saved that story for another time. I think I had you guys believing in me up to this point. crap! I'll save the story about the fire department and police closing off my neighborhood becasue they got a call of an "explosion followed by a column of flame" I thought it was cool. They didn't! Crap I did it again. Scratch that. Soooooooooooooooo With all that beign said. I read through the Bently manual last night. Fantastic! Much better than my generic Bosch book. I already have the fuel gauge hooked up and next chance I get will start getting pressure info and diagnosing. I will post what I get for metrics so you guys can help me diagnose. I'm on vacation for a week starting tonight so there will be a pause until then. Gunter, Kicked any puppies lately that came up to you looking for a pat on the head? Shazam! Sorry I love a good banter. Don't feel bad.
1973 911 T Targa |
PS. Good point about the two plugs getting switced, CSV and other blue thingy. I wondered that when I first noticed one was disconnected. I tried to see if I could expose any part of the wire to see insulator color to reference wiring diagram. No luck with a quick glance. What would I be looking at with a meter to tell which is which? My first guess would be that when cranking starter there would be 12v at CSV until RPM kicked on. What is the blue thingy connector ( I know I know it's the draft flapper switch) gonna read? Probably just a steady 5volts or something?
1973 911 T Targa |
Thread Tools | |
Rate This Thread | |
