Questions before LR P2 order
Stock 84 Carrera. I want to put 17x9.5 P2's in back. Will they just go on with no rubbing issues?
I would lke to stay with 17x7's up front to keep steering nimble for street driving. Yes? No? Should I just go with 17x8's up front. Will there be issues with 17x8's up front? If it's just a little fender rolling, then no big deal.
Those P2's are pricey but as far as I'm concerned a must have item. Cheers!
Reverend Ray
84 Carrera Coupe "DAS-V2"
GruppeB #2119
Volvo V70SE-Wife mobile
Nissan Frontier-Home Depot mobile
Old 11-16-2006, 10:57 AM
Bill Verburg's Avatar
P2? the use of any wheel is posited on the correct width and o/s
9.5 rear wants ET 19, 8 front wants ET 25-30
17x9.5 can be used w/ the right tires and some work at the lips and oil lines and trailing arms. Unless you are racing and need the last nth of performance I would stick w/ 9s
Same at the front, you can use 8s, but depends on the tire, wheel width and o/s
Bill Verburg
Old 11-16-2006, 12:57 PM
