Oxygen Sensor Thread Pitch / Sensor replacement ?
Stupid question - I was able to get the oxygen sensor off of my 91 964, but upon closer inspection the top 50% of the threads are either rusted or cross threaded - the sensor that came off appears to have been forced on.
So what are my options - I would rather leave the cat in place. Can I use something like this:
http://www.sjdiscounttools.com/hel4833.html
They sell them with M18x1.4 and M18x1.5, so which is it?
Ideas, suggestions?
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 11-16-2006, 07:29 PM
I have also thought of running a tap through it, but what are the chances of getting the threads to match up, since there aren't any for at least 2mm of the bung.
Charles Navarro
Old 11-16-2006, 07:46 PM
You do not have permissi
john70t's Avatar
Take off the cat and have a new bung welded on at a muffler shop.
Or get a threadpitch gauge and order the right tap.
There was a trick tap set mentioned in one of the threads that opened upafter insertion- so that the shavings were pulled out with the ap.
Old 11-16-2006, 09:01 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Helicoil is your friend in this case.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 11-17-2006, 03:36 AM
Somewhere in the Midwest
MotoSook's Avatar
Charles, it should be 18X1.5. I'd just weld a new bung on there. Bungs are a few bucks a pieces.
Old 11-17-2006, 04:45 AM
I was able to find a tap at Napa and ran it through very carefully with some tap magic and it cleaned up very well. New sensor threaded in smoothly - I made sure to use good anti-sieze there too! When and if it needs changing again, I'm sure the bung will be toast and that will give me an excuse to put in a cat bypass :-)
Charles Navarro
Old 11-17-2006, 08:39 AM
DW SD's Avatar
You could also cap the bung and weld a new one in.
Glad you got it sovled for the next 50k miles, though!
Doug
1971 RSR - interpretation
Old 11-17-2006, 12:33 PM
Zeke's Avatar
You had nothing to lose. Good job.
Old 11-17-2006, 02:15 PM
