engine and under rear pics
I want to see some under engine pics, most notibly upgraded heat exchangers...
post em up
Current: 1973 914/4 project. FOR SALE |
SSI's with Ben's Muffler on a 79SC
![]() ![]() You will need to change the oil lines.
79SC, Wevo Shifter, SSI, Koni's, MK Muffler 85 944 Stock Past Porsche's 87 944 87 928S4, I was young and dumb 99 Boxster 70 911T Last edited by scottcip1562; 11-13-2006 at 04:50 PM.. |
sweet
Here is a bad picture of my 930 headers.......
1988 Porsche 930 Factory Slantnose 2011 Porsche Panamera Twin Turbo 1974 Porsche 914 2.0 Phoenix Red 1965 Shelby Cobra Replica- 428FE 2007 Mercedes SL55 P30 Package |
SSI's & Dansk Muffler
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Crotchety Old Bastard
993 Bishoffs on an early engine.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Dixie Region R Gruppe
Instagram @phillipkj4 1980 911 SC Backdated Viper Green 1992 Ferrari 348TB Last edited by w21055; 11-12-2006 at 05:51 PM.. |
Wow, I thought mine were nice!
A picture of a 2.7
After Before
Mark Isaak 1974 Carrera Targa - Light Yellow, Being driven 1974 Carrera Targa - Orange, Being restored 1974 Carrera Targa - Lime Green, Being pampered 2017 Macan |
That pic gives me hope Mark. The PO, as well as the PO before that seems to have NEVER cleaned the underside of the car! What did you use to clean it so well (other than alot of elbow grease)?
Thanks, Mike
Mike '84 Grand Prix White RoW Carrera |
I wish I could have cleaned it while it was in the car! The before and after are a result of a complete rebuild. Hopefully, the oil leaks have been addressed and it will stay clean for at least a while!
Mark
Mark,
Looks great
What did you (or 'they') clean it with? Clean it in a vat, or lots of elbow grease? I've always used Simple Green, but I've read on Pelican that some people don't like it - not sure if they don't like because it doesn't clean well, or because of the god-awful smell...
Again, Mark, it looks great! Here's to hoping it stays clean for many, many miles!
cycling has-been
What I tried to do last April
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
MBruns for President
B & B
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Simple Green corrodes Al - there are long threads on whether USAF dissed it or not for aircraft maint. (apparently not). Be real careful if you do use it.
Always clean first with a scraper, and then paper towels or rags. The next step is a pressure wash - and HOT water is great. Detergents & solvents are the last step. Be sure not to just let everything go into the street drain - that goes to people's drinking water and to your supply of seafood. The best thing I've found is to call around to car washes until I find one that _does_ recycle their wash water. Then I use their self-service high pressure hoses. I can do that hundreds of times for the cost of buying a pressure washer, which woud just sit and take up space in the garage.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Bill K are those "thermal reactors" still mounted on your 77 Turbo? I've always heard these should be removed to help the exhaust valves last a bit longer. If you don't need them to pass smog I'd ditch 'em.
I'm not too familiar with turbo motors so if they're not thermal reactors then ignore my comments
Doug 1964 356C - "Olivia" 1968 912 - Slate Grey |
cycling has-been
spud, those are ss oem euro heat exhangers.
LOL, I know what those are
A picture is worth a 1000 words:
River Rat
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
911C3 mit 3.8RS
![]() 993mit Fabspeed cat by pass
