Johnb911's Avatar
shift bushing help
I can't figure out how the two bushings come out of the shift coupler.
I have detached it from the back with the allen key and I cannot see how the ceter pin would come out.
Am I crazy?
john
79 911SC row
Old 11-19-2006, 02:28 PM
Early_S_Man's Avatar
Porsche Crest
The cross-pin is a friction fit in the center block ...and you have to remove the coupler from the shift rod. Be sure to mark the axial and longitudinal position with an indelible 'Sharpie' marker.
Only method I have ever used is easy & safe ... unlike pounding with heavy mallets or hammers!
1. Medium-to-large bench vise is used as a press ...
2. From your collection of deep 3/8" drive & 1/4" drive sockets select one large enough to allow pin to slip inside easily with adequate clearance, and another smaller than cross-pin O.D.
3. If vise is on the smallish size [4" or so] you may need both a regular and deep socket in each size.
4. Slip large socket over pin on one side, and align small socket with pin, and slide the 'sandwich' between vise jaws while tightening vise. Tighten vise slowly, making sure small socket stays aligned with axis of pin.
5. Assembly is essentially the reverse of the above.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-19-2006, 03:03 PM
scottb's Avatar
I tried the mallet method. I ended up breaking the coupler.
Warren's advice, as always, is right-on.
1984 Targa
Old 11-19-2006, 03:45 PM
dm36415's Avatar
Follow Warren's advice, I did mine the same way about 2 weeks ago and it worked like a charm.
_________________
Dave Miller
1977 911 Targa 2.7
Old 11-19-2006, 05:02 PM
Johnb911's Avatar
thanks for the advise
john
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 11-19-2006, 05:28 PM
Dixie Region R Gruppe
w21055's Avatar
Nice advise, I just did the ones at the shifter tonight(what a difference!) and I am thinking about going with the wevo coupler, what do you guys think about that one?
I still have to do the bushings there, so I figured why not just swap it.
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 11-19-2006, 05:41 PM
