(the shotguns)
Does it matter which rotor i get for distributor on 72?
I noticed Pelican has several rotors available for the longhood Bosch distributor. I don't know which i have and need to get my order in this morning if possible.
Is the only difference in the rev limiter? Motor is a '72T w/ webers and supposedly 2.2S pistons, cams etc. Thanks, Erik
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Senior Member
There are several flavours available for this application. Rev limiter is part and there are versions that are plain rotors, that is without the rev limiter built in.
Would try to limit rev limits to 6200-6400 and no more unless you are sure that the engine is in good condition and descent parts inside.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
(the shotguns)
No problem limiting rev's to 6.2 i'm just wondering if there are any other differences in the rotors. Thanks!
If rev limiting rotor is not needed, try a '74 Beetle. Works great!
Mike B. '72 911E Coupe Early "S" #1065 |
