Throw it on the ground!
Can anyone confirm Fuch factory finish? (Polishing progress pics)
Can anyone confirm what the factory finish is on fuch outer rims/lips (not the black center I know it's anodized)?
I ask b/c I've seen conflicting information on searches RE polishing. Some say the the whiteish discoloration on 19 year old wheels is silver paint/ clearcoat or silver anodize vs plain and simple oxidation. I've started working on mine by hand w/tires on using progressive sandpaper grits. The results are looking great and I've got the patience to see it through. However, the more I work them, the more what I'm taking off to get to the mirror stage looks like paint or some time of coating. If so, there's got to be a better way to strip off vs elbow grease. I can post a pic if it helps any on a partially completed wheel. Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 12-11-2006 at 05:01 AM.. |
backwards?
I think you have it backwards, the lips are anodized and the black is painted.
By using sandpaper you have damaged the anodizing (which is very tough). You can use Easyoff oven cleaner to remove anodizing pretty easily, then polish. Best bet for most people is send them off to the guys that do it for a living, you will be much happier! I know there are exceptions, but it's a long process to do them your self! Good luck Jeff Last edited by Jeff Jagusch; 12-04-2006 at 10:57 AM.. |
GAFB
If you're getting to a 'mirror' stage on the rims, then you have stripped the anodizing and are polishing the naked alloy. They will now oxidize relatively quickly and require frequent touch-ups to maintain the mirror finish.
Jeff is definitely correct, the wheels are anodized, then dipped in black paint. What kind of finish do you want? Original? Check out Harvey Weidman (search here on the board).
Several BMWs |
Hey Dave,
Funny thing, we sent out the wheels on the '86 (my dad picked up from you) to Al Reed for an RSR finish.
The car is painted and being put back together in Iowa as an RS replica. Jeff |
Sure enough, I had it backwards. I guess I'll try the easy off method to see If I can cut through the anodize. My objective is to repaint the centers and a highly polished mirror finish on the silver.........then on to the fan!
I'm doing them myself b/c (1) it's my daily driver and I can't send them out and (2) I want to! Thanks for getting me back on track!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
GAFB
Jeff - you guys need to send me some pics!! I haven't gotten any in a couple months. Still waiting on mine to get back from the painter - am on my 2nd painter and nearly 3rd year of waiting. The garage is so lonely...
Several BMWs |
mark, make sure and have the fan clear powdercoated over the polish or your hard work will be flushed down the drain in just a few months. since your car is a daily driver it will turn very fast if you just polish it. for a example of what will will happen take some red scotchbrite and clean a few fan blades very good. this will shine them up pretty good. in just a few short weeks it will be back ugly again..
Progress update: Spent this afternoon polishing my rear wheels by hand. Oven cleaner helped tremendously in removing the anodizing and cut the sanding and polishing time in half. Finished stripping and polishing the rears today. Fronts next then on to repainting the black. Will do some addl sanding and polishing as I only went up 600 and I should get to 1,000 to remove the very fine scratches for a highly polished mirror finish.
Before and After:
&^%$(# Hit the wrong button
Before and After: Four applications of oven cleaner followed by 320, 400 and 600 grit wet sand paper using WD40 instead of water followed by Mothers polish and a mini polish ball Fronts still anodized, rears polished Love the new ATV jack!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 12-11-2006 at 04:36 AM.. |
Very Nice!
Doug ![]() 84 Carrera Coupe - Black (the Goth look) ![]() The more I learn, the more I realize I don't know
The whole wheel was anodized, then the centers painted over the anodize, then clearcoated.
AFAIK, there was no clearcoating over the anodized and painted finish from the factory.
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Where do people get this info...and then make grand pronouncements "as if correct".. ??
???? Fuchs were never clearcoated..... -Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 12-11-2006 at 06:10 AM.. |
I'm not the one making a pronouncement here, but I can read...... |
Nope, no clearcoat over anodise.
Mainly because the anodise needs oxygen to work right.. Kind regards David |
Dixie Region R Gruppe
They look great. I have been thinking of doing the same thing.
Instagram @phillipkj4 1980 911 SC Backdated Viper Green 1992 Ferrari 348TB |
TT
Yes....not trying to be argumentative...but HISTORICALLY...since 1965...no Fuchs wheels were ever factory finished with a final clearcoat...
I'll stand down if this started happening in 2005 ( or whatever) for newly released Fuchs. But for clarity...this was never the case before and it is well known that it wasn't in the past.... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
As a matter of interest and in the pursuit of truth... yes, please post the shipping label that indicates clearcoat. I would also like to see if the print label was made here ( USA -side, perhaps by a re-packager)... or in Germany from the originating manufacturing ( or Porsche) source.
- Wil
The confusion may be from the fact that Fuchs wheels are "clear anodized." There are various forms of anodizing, rough, clear, tinted... Fuchs factory street wheels are clear anodized; never clearcoated.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
