915 Rebuilt - No reverse!!!!
I may have screwed up my 915 rebuilt. So far no leaks. I just installed both engine and tranny. Prior to putting it all together (wiring, oil lines, oil, etc.) I though I would check the shifting.
I installed the clutch cable. I depressed the clutch, shifted into 1st, 2nd, 3rd, 4th, and 5th successfully. However, I could not shift into reverse.!!!!! Where did I go wrong? Help!!!!!
Could it be that little 'rod' that is supposed to activate the reverse switch?
It could very well simply be a mis-adjsutment at the shift coupler.
Another possibility is that the reverse lockout tab on the top of the shift housing is hanging up slightly on the tab welded onto the shift rod. Also an easy fix (if that's the problem). |
Immature Member
As the car is not running, try having someone give the car a little push while you try reverse. Maybe the gear teeth are just clashing?
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" Last edited by dentist90; 11-24-2006 at 07:36 PM.. |
Immature Member
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
It's poltergeist! I just went to the car to try it again. And now it shifts into Reverse! Really freaky.
The rebuild was completed 5-6 months ago. Did the gears just need time to 'loosen up'? |
As I understand it, reverse has no syncro-gear. It is possible for reverse not work, if the car is not running and the gears line up a certain way. Had the car ben running? If so, did you let the clutch out while in neutral, then try reverse again? Just some ideas...
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
