HarryD's Avatar
I warn all of you to be very careful using muriatic (hydrochloric) acid. It does a great job etching metals but you need to watch its progress and be sure to completely neutralize it prior to your next step.
If you are NOT fully aware of the hazards of hydrofluoric acid, DO NOT TOUCH IT. IT is nothing but bad. Bad. Bad news.
Ospho, naval jelly, rustmort, and all the other phosphoric acid containing are the way to go. The advantage is that this acid reacts preferentially with the rust so the attack to the good metal is minimal.
Old 12-14-2013, 04:44 PM
ROW '78 911 Targa
timmy2's Avatar
I'm going with what Harry recommends, as from what I can recall from talking at a cars & coffee a long time ago, I think he has some experience as a chemical engineer..... and rattle can bus painter extrordanaire!
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-14-2013, 11:10 PM
H-viken's Avatar
This is what I like with the electrolysis - it doesn't touch the healthy metal. Plus it leaves no residue.
/Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 12-15-2013, 01:41 AM
I've used many types of rust converters including a rattle can product from Rustoleum called "Rust Reformer".
Available in WalMart.
Converts the rust plus leaves a coating of flat black paintable surface.
Very handy for certain applications. Including gardening tools - I sprayed a machete blade yesterday to help manage rust issues.
Old 12-15-2013, 04:47 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Here, here!
Muratic acid, is a great compound, but to use effectively you have to understand it completely. It is a powerful rust, plating(zinc, cad ect) remover. I use it to prepare steel for TIG welding, where oxides and plating metals will contaminate the weld zone. Used properly, it works well, used sloppily is incredibly dangerous, splashing and fuming are just a few hazards. Drop the wrong material into the mix and you will be rewarded with a hazmat mess, with the resultant trip to the ER. I only open the jug when a charged hose full of tap water is close by my hand and with full face protection. When you get this stuff on your skin, you will know immediately.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 12-15-2013, 11:21 AM
Regenerated User
72doug2,2S's Avatar
Sub'd
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 12-15-2013, 01:12 PM
