Stahlwerks.com
I head to the track on thursday and just found this on my oil line. Was just starting when the thermostat opened up, about 2k rpm.
Can I just sweat this line with some lead and seal it back up, or is it doomed to be replaced? Its right at the joint of the tube to the fitting.
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Grand Am/IMSA Data Guy
I have Belzona, which is a two part epoxy. I keep it in my track box just for this type of problem. If you take the line off, it should be silver soldered (I think).
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
The chance of getting a good solder on that is small. With some epoxy like Belzona (over priced if you ask me, but good stuff) you might get by for a little while. Some JB weld should work in a pinch.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
The lines are brass and I have found them easy to braze.They would need to be empty and sanded clean though.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
If you have access to Wurth Oil Resist sealant, it will get you thru the weekend. Amazing stuff. But clean the area very well with wirebrush and brakekleen solvent. Good luck!
Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900 |
Stahlwerks.com
I'd love to find the wurth oil resist sealant, but have no chance of finding it in this little burg in NC. Any domestic equivalents?
I'll have the stuff in line to pull the line off tomorrow if needed.
Are you going to VIR this weekend? If so, I'll be there.
Push comes to shove, you can make a Aeroquip, Earls, etc. stainless steel line to replace it. |
Stahlwerks.com
Yes, I'll be at VIR. Hope friday isn't rained out, but sat and sun look good.
Stahlwerks.com
Update....
I ended up pulling the rubber line off and pulling the line down into the fender, put a wet rag on top of the fender to keep it cool, then got the torch out and sweated the joint. After 3 days on the track, not a single drip. Woooohoooo! Thanks for the help guys.
Oils well that ends well...
Glad you fixed it in time.
I meant to check back to see if you were going. What group were you in? I was there, but didn't run the 1st two sessions Fri due to rain. The 2nd and 3rd sessions, I got a total of 5 laps. LOL. I just rebuilt my engine and had an oil leak that took some finding. Of course, I didn't find it until just before the 1st session on Sat. Got to run the next rest of the weekend though. |
