Vin-barrett's Avatar
Source for 5amp fuse?
Anyone know where I can get a pack of just the yellow 5amp?
-Vinny
1983 911SC
Old 11-30-2006, 10:45 AM
steve911's Avatar
You might want to call our host - they might have a package of just the 5A.
Or you might pop into a pep boys, autozone, etc.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 11-30-2006, 12:21 PM
retail stores do not carry the 5's.
They are an oddball fuse
-Vinny
1983 911SC
Old 11-30-2006, 12:29 PM
yogi's Avatar
I got them from NAPA auto parts. It took the local store near my house 1 day to get them.
Jerry Baer
87 Carrera Coupe
Old 11-30-2006, 06:57 PM
lally911's Avatar
I got them at auto barn a while back.
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 11-30-2006, 07:22 PM
Early_S_Man's Avatar
Porsche Crest
Find a parts store that carries Littlefuse or Buss [or Bussmann] brand fuses and see if they can order a few boxes of GBC 5 fuses ... exact replacement in a ceramic/glass fuse:
The above screenshot came from the 2002 Automotive-OEM catalog.
http://www.bussauto.com/shared/products/catalogs/
http://www.littelfuse.com/data/en/Data_Sheets/aftermarket-8.pdf
The following Littefuse distributor has the GBC 5 fuses in stock, $20 minimum order:
http://fusesunlimited.com/locations.html
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-01-2006, 09:36 PM
Eric-325I's Avatar
I bought two boxes of each fuse needed for my baby at NAPA. They had them all in stock and were dirt cheap.
Eric
'79 SC Silver over Black... Sold
Old 12-02-2006, 09:27 AM
3.2 CAB's Avatar
I just bought 8 German Car fuse kits at Walmart for $1.00 a pack. Walmart is dropping this item from their inventory and are clearancing them out. They come with a fuse puller, an an assortment of fuses, including the YELLOW 5amp fuse, and the rest of the normally used fuses. So, go check your local Walmart to see if they stil have any of them. I thought that $1.00 a kit was a pretty good deal. Just my $.02.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-02-2006, 10:30 AM
randywebb's Avatar
Say, Warren, is there any adv. to the ceramic/glass packaging?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-02-2006, 10:43 AM
Porsche Crest
Randy,
Both designs have their drawbacks ... aging and exposure to the elements can cause failures of both types -- even when there is no overload condition!
The glass tube design can fail at the internal solder joint ... and the failure will not be visible! Soldered pointed contact points don't seem to corrode as badly as the ceramic design.
The ceramic fuse design has no solder joints to fail, but corrosion at the ends' contact point can cause overheating of the fuse and fuseholder, and discoloration of the wire insulation for an inch or more back into the loom.
Warren Hall, Jr.
Old 12-14-2006, 12:12 PM
