Valve adjustment - labor charges HELP!!
Complete newbie here in Los Angeles.
We've been getting a worrying intermittent clicking/clattering noise (quite loud) coming from the engine. 1991 911 140k Took it to our local Porsche repair shop. They said it was very low in oil but after topping up this has not stopped the "clicking". They said they need to look at the valves and quoted us 14 hours of labor at $90 an hour!!! That $1300 without any parts Is this correct? Is it really that big of job? Are we being totally ripped off? From other posts on these boards it seems like a valve adjustment can be done in 4-5 hours. Any advice much appreciated..... |
Better in Person
if you are paying more that 350 for a valve adjustment thats a problem. that should include gaskets, and supplying your own oil.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
THE IRONMAN
Bazza...why don't you try to do that adjustement yourself...It is very well explicated in the technical section of Pelican...and will be rewarding for you as well...
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
this is a C2, so $350 incl. parts is way too cheap for all the work required to do a valve adjust. maybe the shop that quoted $1300 quoted a full service price, which would be in the ballpark. call TRE in n. hollywood.
You might not be communicating well with the shop. If you ran low on oil and they want to "look at the valves", it's possible they want to pull the heads and/or check the guides. That's a lot different than a valve adjust. Like JW said, get a 2nd opinion at TRE.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Don't know your location in LA, but Otto's in Venice is a very capable shop. I'm very well acquainted with TRE in N. Hollywood, and if they're closer, you can definately count on them.
I'm sure you could coax some locals over to your house with a few beers and barbrie then get the work done from them or get directions.
I agree with John Walker. It sounds like they quoted for a complete service. (8 hours max) 14 hours is just padding their pockets unnecessarily.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
Thanks for all the replies.
I spoke to both Precision Tech and TRE. They were great and both seemed surprised by my orginal quote. TRE said it would be about $1250 for a FULL service (including valve adjustment and plugs) and Alex Wong said that just an adjustment should be 4-6 hours. I went back to my original mechanic (LA Meister on La Cienega) and he confirmed the quote of 14 hours ($1300) was for the "valve adjustment". When I said that they were quoting 3 or 4 times more for labor than other places they just said "well it's a lot of work". This isn't the first time that we have been suspicious of high labour charges from this company. in the past they've wanted to charge a half hour labour charge for changing an electric window switch which someone else changed for me in approx 15 seconds. Picking up the car tomorrow and driving it down to Alex Wong : ) |
This can't be the same MM that we hear about, is it? Good luck and excellent choice now.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler |
one of gods prototypes
welcome to the board......it is customary to post a pic
![]() you'll find the search button up top is your best friend
Brought to you by Carl's Jr. |
fyi, I have done great business with Alex. I am planning on having him align and corner balance my 911 next.
I'm not really sure, and for me this is hearsay, but doesn't valve adjustment on a C2 require some messing about with engine mounting, lowering, etc., for access. That does sound like a lot of work!
Fixed for a fraction of the price
Well the moral of this tale seems to be to shop around, get second opinions and to go see an expert.
After the original quote of 14 hours of labor just to "look at the valves" we took it to Alex at Precision Tech. In one afternoon he diagnosed the problem as a blocked oil squirter and fixed the knocking noise. C2 sounds great and the total charge was $356 a saving of at least $1000. going back to see Alex again for a full 130K service. Thanks to all for your advice and input. |
twin plug, $500, valve adjustment couple of seals. and Oil.
Eastern Pa
Have you ever felt suffocated while watching the Oxygen Channel? People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself. 88 Carrera |
