Hi Gunter,
We'll be doing a dyno day in Vancouver in the spring if you can wait until then. There won't be much tuning going on (depending on how many cars we have to get through) but you will get 2 to 3 pulls and an AFR plot for each run. Then, at least you'll have some numbers and can compare to the other cars that are there that day. Last year we had 16 cars but none with an engine simlar to yours. If you're interested keep an eye here for an announcement. |
I also agree that many power claims of mods are way overstated. I'll have to go back to the book I was referring to and check it out...I know there were several different 3.0 rebulds displayed there...a 3.0, a 3.2 from a 3.0 and a 3.4 from a 3.0....different cam options, exhaust options, etc.
1983 911SC Coupe 1985 928S 1987 944 Coupe 1992 Carrera C2 Coupe 2006 Cayenne S |
Somatic Negative Optimist
Thanks. Where in Vancouver is the Dyno?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Some more questions:
Re: Crank vs. wheel. When HP-figures are used for "at the wheel", what gear is the transmission in? What gear is used on a Dyno? Thanks.
As long as the #s are correctly entered then any gear can be used but it's best to use as close to 1:1 as possible to remove another issue, inertial drag of the driveline components, from the equations, there is far more of this in lower gears than in upper The best most accurate #s short of an engine dyno come from Dyna-Pak dynos, they at least remove the tire from the equations and they also remove a lot of the drama that a poorly secured car on a dyno can create.
Thanks, Bill.
What's cwp?
Czar of C.R.A.P.
I will go with 210 rwhp only based on my stock 3.2 with B&B muffler. I would think with the mods he would out pull a stock 3.2
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Black and Blue
Im guessing 208.7 rwhp...
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
So, what's cwp?
Many thanks.
I am beginning to understand a lot more about the Dyno-issue. In the spring, I'll tag on with a group going to a Dyno in Vancouver. The HP/torque issue is secondary to me; mostly interested in having the correct AFR throughout the RPM-range. I think the distributor plays a major role in this. My 3.0 did run very well with the standard 5deg BTDC. I remember posts were people set their 3.0 liter to maximum total advance. Didn't have any success with that; as soon as I go more than 5deg BTDC, it didn't run well in idle. Now, with the SS 3.2, I plan to experiment with the timing to find the optimum setting. Any thoughts?
Light,Nimble,Uncivilized
![]() Can't wait to see and hear the new lump Gunter!
Drago '69 Coupe R #464 |
Will you post pictures of whatever mods you plan for the new addition? What does it need? Is it running?
It's getting new torsion bars (21/29), SC aluminum front cross member, SC rear banana arms, SC brakes all the way around, new spring plates, an early S thru the body sway bar in front and a later style bolt on SC rear bar. Koni Red struts and inserts up front and Koni Red dampers in the rear. All bushings will be inspected and replaced as required. I also have a f/g S front bumper, an early style dual out muffler and H-4's on the way shortly. I'd also like to add a f/g rear bumper at some point. All mods will be reversable to stock condition.
Sounds good.
Will you change the 4-cyl. 912-engine with Solex carbs to something better?
Didn't have any success with that; as soon as I go more than 5deg BTDC, it didn't run well.
Gunter In your last post I think that you have confused initial advance and total advance. Initial advance is when you time the engine at idle.....basically the engine is turning very slow and you are firing the plugs at a crank rotation that will generally be conducive to a smooth running engine. Total advance is the initial plus the distributor advance. Inside the distributor, there is a cam with weights that will advance the timing as the RPM increase, via centrifugal force. The reason for this is that as the engine RPM increase so do the opening and closing of the valves and the filling and emptying of the cylinders. The advance is necessary to keep the timing, firing of the plugs, in sync with these events and insure that the engine will run well and produce the designed hp. So the firing of the plugs will have to change to continue to take advantage of the engine power.......too much advance leads to detonation, too little advance results in loss of power.
Al Morales 77 911 S (930 steel conversion) 88 BMW M3 79 Honda CBX |
Thanks Al:
I understand the workings of the distributor (Vacuum and centrifugal) My post should have said: When I adjust total advance to some of the higher/maximum settings some people have tried, the engine doesn't run very well in idle.
My motor (supposedly the same as yours) only makes 186HP at the rear wheels. Whatcha got in there? Jess |
