77911s
Guest
Posts: n/a
replacing turn signal switch
has anyone done one of these? do you have to take off the steering wheel to get access?
Also wondering how to remove that bloody "shell" around the steering column.
77911s
Old 09-21-2000, 01:52 PM
mikez
Guest
Posts: n/a
Yes you have to get all the way down inside the steering column....it is not real easy until it is disassembled, then it is all plugs....I just did mine. I have an extra swirch if you need one....
Mike
mtz1@home.com
Old 09-21-2000, 04:38 PM
Mrdi
Guest
Posts: n/a
Mike if you did yours recently and you have an extra switch ,did you find the problem was other than the switch?
I just took delivery on a new switch and there are about 5 or 6 different plug ins. How much time should be allowed, any recommendations, I plan to do it this weekend with Bentley as a resource.
Mrdi
Old 09-21-2000, 05:24 PM
wckrause
Guest
Posts: n/a
Once you get the steering wheel off, it's very easy. All of the wires are color coded, and will match the existing wires. Just note how the old wires are routed and where they plug in. I think I did it all in less than an hour, with just the old wiring as a guide.
I've heard of some people trying to fix the switch, but if it's bad IMHO you are better off replacing it. Also, pull the fuses for all of the lights, (turn signals, parking lamps, high and low beams) and use a test lamp to verify that everything is working right.
Bill Krause
'79 911SC Euro
Old 09-21-2000, 08:00 PM
