robfix
Guest
Posts: n/a
front jack points
I've discovered a fuel leak and in order to get a closer look at where it is coming from I need to remove the steering plate cover. I'd like to jack up the front end without damaging the car or myself. Is it okay to jack on the auxiliary support (where the control arm meets) and to put jack stands on the front receptical(cross member?) of the transverse control arm? And is this also referred to as the torsion tube and the bar at the front going from right transverse conrol arm to left transverse control arm called the cross member?
[This message has been edited by robfix (edited 09-25-2000).]
Old 09-25-2000, 09:07 PM
john rogers
Guest
Posts: n/a
You did not mention the year, but most 911's I have seen have jack pads on both side, the front one is just behind the wheel well and just iside the rocker. The rear one is just forward of the rear wheel well. They are a raised square of metal. I'd recommend using the side jack point and putting stands under one side at each pad. Good luck.
Old 09-25-2000, 10:09 PM
robfix
Guest
Posts: n/a
sorry, '78SC - thanks for your reply John but I don't see the pads you refer to.
Old 09-25-2000, 10:15 PM
Early_S_Man
Guest
Posts: n/a
The 'crossmember' is the aluminum or welded steel piece that is bolted to the tub and connects the two rearmost pivots of the A-arms, and is where height adjustments are made, at the rear of the torsion bars.
One of the best points for jackstands are the forward mounts of the A-arms. I prefer to use the factory jack receptacles and a 'jack plate' adapter with a floor jack to jack each side of the car 4" to 6" at a time, alternating sides to get to the desired altitude. It takes a bit more time, but there is no danger whatsoever of damaging the car with a jack.
Warren Hall
1973 911S Targa
Old 09-25-2000, 10:21 PM
robfix
Guest
Posts: n/a
thanks Warren - I might be beating this to death but want to be sure and nead clarrification on the a-arms and forward mount. are the a-arms the same as whats called the transverse control arm in my factory manual and the forward mount the point where the bar under my front condensor goes into those a-arms?
Old 09-25-2000, 10:38 PM
Early_S_Man
Guest
Posts: n/a
Yes on the transverse control arm equals A-arm ... what most people in industry would call almost any kind of triangular lower control arm!
And, yes, the point immediately behind the end points for that protection bar for the A/C condensor is where I recommend putting the jack stands.
Warren Hall
1973 911S Targa
[This message has been edited by Early_S_Man (edited 09-25-2000).]
Old 09-25-2000, 10:55 PM
