BReyes's Avatar
Where do I get an accelerator block to bolt to the pedal for track use to bring it up
Where do I get an accelerator block to bolt to the pedal for track use to bring it up an inch or so?
Thank you.
Regards,
Bernard
Old 12-12-2006, 08:00 PM
Won Won is offline
Won's Avatar
Glue on a piece of wood about one inch thick and painted black.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 12-12-2006, 08:08 PM
Insane Dutchman
My pedal has some adjustment....if my fading memory serves. I think there is a clevis on it that will move it a bit...maybe not an inch, but some. You can also adjust the brake pedal position a little if you have power brakes, so you should be able to get the positions you want without having to resort to blocks..
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 12-12-2006, 08:34 PM
Navin Johnson
TimT's Avatar
Our 2003 GT3RS, which ran at Lemans, and other races came to us from Racers Group with a very hi-tech spacer on the gas pedal, this was the car Kevin, and Liz drove..
the spacer......... 3/4 in plywood screwed over the stock pedal
'69 911 GT-5
'75 914 GT-3
and others
Old 12-12-2006, 09:44 PM
Southern Class & Sass
Dixie's Avatar
In case you're not aware, the gas and brake pedal heights are adjustable on a 911.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 12-13-2006, 04:24 AM
Registered ConfUser
If you go this route, it might be prudent to use screws rather than glue. It'd be a shame to lose your woody in the height of action (track...of course).
Old 12-13-2006, 04:31 AM
Cymru am Byth
carmad's Avatar
I cut a piece of 3/4'' plywood and used two small machine screws and bolts, painted it black, took about an hour to do. Works like a charm.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 12-13-2006, 06:08 AM
MBruns for President
JeremyD's Avatar
Re: Where do I get an accelerator block to bolt to the pedal for track use to bring it up
Thank you.
Regards,
Home Depot or Lowes
Old 12-13-2006, 06:19 AM
GFCC
Jeff's Avatar
I used another 911 gas pedal. Shaved the bottom flat and ran thru bolts and nuts to secure it to the other pedal. It is the perfect height for heel/ toe and when you look in the car it looks like a regular gas pedal. They are very cheap if memory serves.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 12-13-2006, 06:21 AM
Irrationally exuberant
ChrisBennet's Avatar
Bernard,
I found the stock gas pedal height to work fine at the track where you are pressing the gas pedal further down. (The pedal was too skinny for heel-toe with my small feet however.)
When I went to big brakes I did end up lowering the brake pedal some.
Be aware that if you raise the brake pedal with the adjustment at the pedal end, you will need to adjust the throttle linkage at the engine end otherwise you will bend your throttle linkage.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-13-2006, 06:55 AM
