| Registered |
				what does *yours* weigh?
			Following on the "2690 is too much" thread, would people post their weight and major mods done (FG parts, gutting, etc). For the nascent 911spec thread I am trying to figure some realistic weights for 3.0/3.2 powered cars.
|  08-09-2005, 09:02 PM |
| Automotive Monomaniac |
			At last weigh-in, it was ~2960 lbs. Stock exhaust and CAT replaced with a Fabspeed dual outlet. Maybe saved myself 15 pounds.
				__________________ 2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) | ||
|  08-09-2005, 09:11 PM |
| Senior Member Join Date: Feb 2000 Location: Lacey, WA. USA
			I've removed a few parts from mine.  A/C (60 lbs or so).  Backdated exhaust.  A few other things.  I think I'm probably in the neighborhood of 2650.  Yeah, that's too much.  I've driven a car that's a couple of hundred ponds lighter, and it makes a BIG difference.  Plus the stiffer suspension.  Much more tossable.  Much more predictable.  (especially with refreshed suspension parts like spring plate bushings)  Besides A/C, the biggies are bumpers and seats.  My engine is out now, and the sound pad's gonna go.  I don't really think it does anything.  Maybe it limits my ability to hear that musical flat six.  If a guy were serious about weight, it might just be the best to strip the car completely, sand and paint, and then reassemble using only those parts that are necessary to take the car around a track once.  FG parts are *****.  Somebody is gonna bump them while trying to park near your car, and then they're toast.  But hey, if your goal is 2000 lbs, then FG will be necessary.
				__________________ Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" | ||
|  08-09-2005, 09:16 PM |
| Registered |
			2,633 pounds on the corner balance scales at Hergesheimer with 1/2 tank of gas, about 10 gallons, so about 2,570 pounds empty. RS door panels. AC delete. No toolkit. Manual seats. Smaller battery than the giant stock Carrera version. No engine bay soundproofing. Washer bottle empty. As far as I can tell, everything else is still there. | ||
|  08-09-2005, 10:34 PM |
| drag racing the short bus Join Date: May 2002 Location: Location, Location...
			2280 with an 1/8 tank of gas. Interior has been hollowed of everything non-essential to driving: stereo, speakers, rear seats, parcel shelf, soundproofing. Stock seats have been replaced with lighter weight seats. Engine soundproofing has also been removed. In the trunk area, no spare, no tools, and a lightweight battery in the smuggler's box. Except for the ducktail, there is no fiberglass on my car. If I had a simple harness bar instead of the Autopower roll bar in my car, the weight would be 2230. But the Autopower is both bolted and welded in to give additional rigidity. I'm slowly learning the more I lighten my car, less needed are engine mods as well as many suspension mods. Couple a lightened SC with a 7.31 r/p and you'll have a rocket. I've driven many 911s more powerful than mine with harder suspensions, yet in most situations, none feel that much faster or feel they handle that much better.   | ||
|  08-09-2005, 10:43 PM |
| Registered Join Date: Oct 2002
			1015 kg=2230 lbs ? Fiber Duck,hood,fenders and bumpers. Backdated heat no airco and minimal interior this is a 87 no sunroof coupe.
				__________________ 87 Carrera Backdate | ||
|  08-09-2005, 10:49 PM |
			Two other things: 1) get rid of the washer bottle - that should be about ten pounds, and 2) the stock steering wheel is supposedly very heavy.
|  08-09-2005, 10:51 PM |
| Registered Join Date: Aug 2004 Location: SoCal
			2,635 pounds on the corner balance scales at Hergesheimer with 1/2 tank of gas
				__________________ carrue529 1987 911 Carrera S.Wong chip|ElginCams|GT3 oil pump|short gearing|Guard TB-Diff|22/29 Hollow T-Bars|monobloc calipers|Bilstein HD/Sport|Turbo tie rods|Strut brace|CobraMonza II seats|7, 9 Fuchs|Elephant polybronze bearings F/R|Wevo eng mounts|bypass cat pipe|M&K muffler | ||
|  08-10-2005, 01:30 AM |
| Registered Join Date: Jan 2005 Location: London, England
			Can we have some BHP figures and egine size figures with the cars to see what the power to weight ratio is approx?  aLso if you do know how much your car weighs in kilos that would help us euro guys out. Cool thread.
				__________________ 77 Porsche 911 3.0 Carrera 58 Porsche 356 55 Chevy Bel-Air 72 Volkswagen Bug, 06 Volkswagen T5 14 Yamaha R1, 14 GSXR750, 17 CRF1000 | ||
|  08-10-2005, 02:11 AM |
| Registered Join Date: Oct 2004 Location: Memphis TN
			2710# with a 1/4 tank.  nothing removed,  A/C intact. stereo w /large amp added, and 7/9" Fuchs.
				__________________ ELVIS 84 CAB -SOLD | ||
|  08-10-2005, 03:13 AM |
| Registered |
			My '76 (when it still had it's 2.7) weighed 2310 lbs.  This is with fiberglass F/R bumpers, fiberglass tail rear seats removed and an Autopower roll bar (among other things).  I'm thinking the 3.2 has added about 100lbs, but I've also swapped the factory seats (31lbs each) out for Sparcos (13 lbs each) so the car is probably about 2375 now. Mike
				__________________ Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes | ||
|  08-10-2005, 03:18 AM |
| Registered Join Date: Feb 2002 Location: Central NJ
			74 with steel flares & sunroof, no interior, FG bumpers, FG tail, cage, Cobra seats, 3.2 w/ Webers/headers/Supertrapps, racing wiring harness, Outlaw brakes, Firecharger system, 3/4 tank... 260RWHP on Dynapack,  2398#  using digital CB scales. Lou
				__________________ '76 911 "Moneypenny" daily driver '74 911 "JLo" IROC DE Car '03 CRV, '02 Jeep Grand Cherokee '03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft# http://www.nicotra4.hpshare.net/BasketCaseMotorsports/ | ||
|  08-10-2005, 03:22 AM |
| Friends of Warren Join Date: Feb 2004 Location: Surrey, UK
			Well you know mine is a fat pig. 2630lbs = 1192kg To lose weight I have done the following: - no A/C - no washer bottle - no spare - no tool kit - Recaro racing shells - RS door panels - F/G bumpers - no carpets - no soundproofing Still to be done - Odissey battery - remove rear seats - remove soundproofing behind rear seats Items that have added weight - 2 275/40-17 front tires - 2 315/35-17 rear tires - big brakes kit - 72 row front oil cooler + lines - triangulated strut bar - harness truss - 6-point harness - fire estinguishing system I think the wheel/tires are worth ~100lbs over stock and the brakes ~40lbs. Without the rear seats and the battery I should be in the 2580 region. That's 300lbs heavier than Rdane's effort. Half of that is in the brakes/wheels. The car should put down around 262-5 rwhp which would give roughly a 9.7-9.8 lb/hp power to weight ratio. | ||
|  08-10-2005, 05:09 AM |
| Moderator |
			2650# full tank, tools, spare tire, all carpets '76 C3, 993 vram, SCRS trans, 993RS brakes, 235/275 x17 tires, f/g f/r bumper caps(w/ nerf bars under)
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  08-10-2005, 05:15 AM |
| Registered Join Date: Oct 2003 Location: Michigan
			Just weighed mine last week. Certified commercial scale. 81 Euro SC No A/C, stock interior. Half tank of gas 2800# -170 #(my fat a$$) _____ 2630#
				__________________ 1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne | ||
|  08-10-2005, 05:17 AM |
| Registered Join Date: Mar 2004 Location: Higgs Field
			Love that gas pedal, len911.  Thin plywood might save a few ounces over the 2x4.    Anyway, my '72 T non-sunroof coupe is dead nuts on 2300 with half a tank of gas. Fiberglass front bumper, no rear seats, no spare or jack, Corbeau Classic II driver and passenger seats, larger SC gas tank, no air, pretty complete tool kit and spares, stock 2.4 with iron cylinders, Momo wheel, one-piece 15x7 BBS's with Yokohama ES100's 215/60-15's, and a PLYWOOD gas pedal spacer, with a rubber VW pedal over the top to add some class.
				__________________ Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" | ||
|  08-10-2005, 05:25 AM |
| Registered Join Date: Nov 2004 Location: Pacific Northwest
			73 no sunroof chassis -fiberglass bumpers-splitter/ducktail, otherwise all steel -all glass/manual window cranks/rear windows operational -lightweight battery -lightweight carpet kit -RS style early door panels -race buckets/6 points -6 point 1-1/2 inch DOM cage -Momo Mod7 wheel -alloy banana arms and crossmember -adjustable spring plates -ER bushings/offset ball joints -Wevo stress bar/cast camberplates-monoballs -TRG sways -Sanders tubular TBs -Bilstein custom valved RSR style struts/shocks -ERP bump steer -TRG 13 inch front rotors/930 rear -930 calipers -15x7/8 Fuchs 225/50-15 V710 tires -993 varioram 3.6/SSI/Monty muffler -alloy 915 w/chromo bearing plate/billet side plate/LSD -transmission cooler tilton pump/oil lines/oil cooler in nose -930 axles -Aeroquip AN16 oil lines/6 x 24 B & B oil cooler 2230 lbs @ 3/4 tank It's a little over a second slower than GT1 cars at Pacific Raceways near Seattle.     | ||
|  08-10-2005, 06:58 AM |
| Registered Join Date: May 2004 Location: Encinitas (San Diego CA)
			71 no sunroof chassis fiberglass front & rear bumpers ducktail, hood, otherwise all steel, including flares. all glass windows, power windows. lightweight battery - smallest 12V costco battery that I could buy. Custom stainless mount for smuggler's box no heater box or ventilation ducting up front. stripped down wiring harness no sun-visors lightweight carpet kit RS style early door panels fixed Sparco race buckets/5 points on custom steel mounts 4 point RSR style rollbar Sparco wheel alloy banana arms and crossmember adjustable spring plates ER bushings Tarret adjustable sways Sway a way TBs (22mm, 30mm) Bilstein custom valved, raised spindles and gussetted struts+ custom valved Bilstein rear shocks 17x9.5 + 17x11 Lindsey BBS / Fuchs 255 / 40, 285 / 40 Kumho MX tires brakes are 86 Carrera rotors and calipers '86 3.2 + SSi's and MB911 muffler AL 915 72 row front cooler - mocal +4 gallons of gas = 2180 lbs @ corner balance - Mirage International
				__________________ 1971 RSR - interpretation | ||
|  08-10-2005, 08:30 AM |
| Too big to fail |
			What kind of mirror is that?  I like it! Quote:
				__________________ "You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs | ||
|  08-10-2005, 08:51 AM |
| Registered Join Date: Mar 2003 Location: Arlington, VA
			Not only does my car look similar to Randy's, but the weights are really close too: 1975 Non sunroof Chassis Fiberglass bumpers/ducktail, the rest is all steel RS door panels RS carpet Manual door and rear windows No radio, heat, a/c Race seats/ 5pt. harnesses Safety devices roll bar No spare/tools 17 gal. fuel cell Alluminum banana arms Adjustable spring plates Sway away bars Bigger torsion bars Koni adjustable shocks Rear monoballs 911S calipers, slotted rotors 16x7/8 fuchs 8.31 915 tranny with custom 2-5 gears 2.8 L race motor Phase 9 header/exhaust B&B front mount oil cooler --------------------------------------- 2150 lbs @ 1/3 tank last year on corner balance scales 2200 lbs @ 3/4 tank this year with the 3.6L motor conversion sans muffler (so add 25 lbs) at the last local SCCA National event.
				__________________ - James 1975 3.6 RS 2015 F10 535i 2011 911 C2 | ||
|  08-10-2005, 08:59 AM |
