Wer bremst verliert
JohnJL's Avatar
2-wire temp sensor?
Anyone know where to get a 2-wire (ie. not grounded through the engine case) oil temp sensor? The one that is installed under the fan housing near the pressure sensor. I am getting a lot of "noise" on the signal from the alternator and am trying to get a clean signal.
Thanks!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 12-13-2006, 12:08 PM
Tired Member
DaddyGlenn's Avatar
Is your alternator properly grounded?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 12-13-2006, 12:45 PM
Early_S_Man's Avatar
Porsche Crest
John,
Are you talking about a jumping or pulsating needle, dropouts in data, or noise spikes in with the temp data???
The wire to the temp sender has been known to fracture under the insulation within a few inches of the sender, leading to intermittent connection for a while, then an open wire and no data!
If it is truly noise on the signal lead, a coax cable should take care of the problem ... IMHO, RG-174 or RG-188 should take care of the problem!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-13-2006, 01:00 PM
Wer bremst verliert
JohnJL's Avatar
Thanks Warren and Glenn,
All the wiring in the car is new, did it myself so I believe it is done right. I have an externally-regulated alternator and its grounded, as is the engine in several places.
I don't know it its spikes or what...I'll check the logfile. My EFI brain is showing the temp fluctuating by ~10 degrees C and sometimes goes blank. The EFI tuner said he's seen this before and he says its possibly due to the different current put out by the alternator and that a 2-wire sensor has cured it in the past...
I coundn't find the part so I tapped the sensor and metallic-cemented a wire into that, will see later if that helps...won't isolate the ground fully but will get a direct ground to the EFI ground. Maybe that'll help.
Old 12-16-2006, 01:08 AM
Tired Member
DaddyGlenn's Avatar
Very interesting. Keep us posted.
Glenn
Old 12-16-2006, 04:53 AM
