dweymer's Avatar
Custom EFI-What injectors
What psi and delivery rate injectors for a 2.7? For use with megasquirt probably.
Donnie
Currently Porsche-less.....
Old 12-16-2006, 01:12 PM
Navin Johnson
TimT's Avatar
3 bar usually
Knock yourself out
'69 911 GT-5
'75 914 GT-3
and others
Old 12-16-2006, 01:29 PM
rfuerst911sc's Avatar
I'm useing 30lb. per hour on my 3.0. I think the 3.2 Carrera OEM injectors are 24 or 26 lb. per hour.
Old 12-16-2006, 03:04 PM
PCA7GGR's Avatar
I am using 3.2 injectors set @ 35psi on my twin-plugged 2.8 with TWM throttle bodies and Haltech.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 12-16-2006, 03:21 PM
dweymer's Avatar
Thanks guys, so what affect would boost have on this?
Donnie
Old 12-16-2006, 06:43 PM
Send a message via Yahoo to Lukesportsman
You would need to reference the "boost' pressure (manifold psi) to the fuel regulator. To keep fuel distribution correct it needs to elevate its pressure as the manifold pressure increases. You can do this at a 1:1 ratio using injector pulse width to keep A/F in line. You can also use a Vortech/Protomotive FMU to increase fuel pressure at some ratio to "boost" pressure. The latter often works well if your injectors are marginal in size.
Carrera injectors work well if going OEM Porsche or 951 if you want more head room. The 24psi are very common if your going high impedence Bosch type from the Mustang racers and are inexpensive. If its a Mag case...most seem to think 250hp is reasonable safety....24's should cover you, then.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 12-16-2006, 08:35 PM
do you have van wyks/my old stuff??
I have a file I can send you that is ballpark for youe set up with 6 psi of boost
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-17-2006, 05:16 AM
dweymer's Avatar
Ben, nope, gonna make one.
Donnie
Old 12-17-2006, 08:03 AM
