dozer's Avatar
Need help -930 engine in 911SC-
Hi
I have installed the engine in the car (1983 Turbo engine into a 1978 SC car)
Everything looks good but one thing.
The 14pin connector between the engine and the car,is the same but the wires inside the connector isn't matching. Seems like Porsche placed wires for the same function in different places on SC - turbo. The connector is the same.
Does anyone have electrical diagrams showing the difference?
Does anyone have a car(911 SC) with a Turbo engine installed?
If so would you be willing to take a look at your car and see witch pins in the connector, have been switched to make it work.
Grateful for all help.
Thank you
Knut.
"It gets a little bit louder above 5,000 RPM so you can't hear the passenger scream"
Porsche 911 Turbo
Old 10-31-2006, 12:30 PM
dozer's Avatar
Bump
Porsche 911 Turbo
Old 12-16-2006, 02:06 AM
Crotchety Old Bastard
RarlyL8's Avatar
I have a '78 930 engine in my '78SC.
The pins are placed differently in the two applications. If you can tell me specifically what you need to know I will get the information from my notes.
Here is a 930 electrical diagram:
Old 12-16-2006, 07:10 AM
the overboost switch wire, white, is not in the SC plug. the rest just need to have the colors matched up, IIRC. draw out the pin colors and positions on paper for each plug to make it easier to figure out.
206 637 4071
Old 12-16-2006, 09:28 AM
dozer's Avatar
Greate RarlyL8!
Im gonna need to know witch pins is connected to each other.
For example:
In car 14 pin connector - Engine 14 pin connector
Blue - Blue
Red/white - brown/yello
And so on...
Porsche 911 Turbo
Old 12-17-2006, 07:26 AM
