-   -   Replacing spacer Lug Nuts. (http://forums.pelicanparts.com/porsche-911-technical-forum/321775-replacing-spacer-lug-nuts.html)
Paul Ferradas 12-27-2006 12:33 PM
Yeah, they look tapered but there not. PH is closed for the holidays until Jan 2nd.
Wil Ferch 12-27-2006 12:50 PM
I'll say it again...Danny_Ocean...there are no "Grade 8" metric fasteners .... I think you mean property class 10.9 or even 12.9....
Wil
ChrisBennet 12-27-2006 01:41 PM
Wil
The lowest commonly available metric grade is grade/"property class" 8 (for nuts, 8.8 for bolts) which is approx Grade 5 in SAE I believe.
It wouldn't surprise me if wheel lug nuts were grade/"property class" 8's. That would still be stronger than the aluminum alloy nuts that came standard.
-Chris
Jeff Alton 12-27-2006 01:53 PM
Here is a metric grade chart for nuts and screws/bolts......
http://www.fullermetric.com/technical/information/tech_grade_markings.htm
Hope this helps with the discussion of "grades".....
Cheers
Paul Ferradas 12-27-2006 02:24 PM
For whatever it's worth, these nuts have a marking on the back. "J" on the top and the number "8" on the bottom.
Danny_Ocean 12-27-2006 02:38 PM
Wil
Grade 8 SAE...I'm American.
