LinkBack | Thread Tools | Rate Thread |
Somatic Negative Optimist
Looking at the schematic in the Bentley SC Manual 970-02-03, it shows:
Large red wire to starter, Small red wire to fuse 24 (And 23) in the engine comp. Blue wire to idiot light, Brown is ground. Why is the alternator supplying power directly to these 25A fuses for the Rear Window Defogger Relay and Heater Ventilator Relay ??? Why is the power for these relays not coming from the fuse panel in the front?? The power for WUR and AAR is coming from the front, why not for these relays ?? Too high Amp-draw?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
For high-demand accessories that happen to be located in the rear of the car, like the rear window, it makes sense to run current directly from the alternator, through the fuse, and then to the accessory.
Put another way, if the factory did what you propose, all the current would have to run from the alternator to the starter, through the fat black cable to the battery, out of the battery to the fuse box, out of the fuse box back to the rear of the car, in and out of the relay and then to the window. That's a long trip for the current to take, with resulting voltage drop, greater weight and cost for the manufacturer. The current for the WUR and AAR is way, way less than 25 Amps, and it needs to be switched from the front of the car anyway, no relay. Good luck!
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Thanks John, that makes sense.
I see now that the Defogger switch in the dash controls the rear relay but the actual power for the defogger comes from the alternator through fuse 24.
