Where to Look for Rust When Buying a 911
Never seen a thread on this, so when I saw this outstanding example pic of rust in the front pillars, I thought I'd start a thread....
![]() It is the current post on the 'Abandoned' cars thread. http://forums.pelicanparts.com/porsche-911-technical-forum/241262-post-pics-sad-abandoned-porsches-post3013198.html#post3013198
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Other places to check include the 'smile' on the bumper cars, and:
- pull headlights and check the buckets - pull turn signals housing and check back there - rear package shelf - probe underside with a screwdriver, esp. by the front pan Maybe folks would like to add pics so new buyers can be a little safer...
Tree-Hugging Member
Good thread, Randy.
Rocker panels. Underside of doors. Lower corners of windshield and rear window. Fender wells at bottom where gravel and water collect. Longhoods: front of trunk near horizontal weatherstrip.
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ |
-Drain holes by hood shock mounts
-Metal Drain Tube from fresh air vent in to smugglers box (rusting inside out) -Around Battery -Gas Filler area
68 911L |
Slumlord
Rear torsion tubes. When they go you've got trouble.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Wine User
Aftermarket A/C units in smugglers box.
Southern Class & Sass
Dixie Bradenton, FL 2013 Camaro ZL1 |
Pop open the fuel door...move the protector flap out of the way, look toward the trunk.
pozee |
-Front of the rear wheel wells at the top of the door jams.
-Front wheel wells, In the shelf right behind the washer fluid bottle.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche Last edited by khamul02; 01-02-2007 at 07:47 PM.. |
Work in Progress
In no particular order:
1. Where the front bumper mounts to the car: 2. The wheel well, watch in-particular the area around the top of the drivers side shock tower (a hose runs along here and traps water and grime) also watch out for the area behind the cylinderical A/C component: 3. The pedal box: 4. Jack reciever area: 5. Rear seats under the cushions ( I dont have a pic of this one who - hoo) 6. Rockers / door jams 7. Battery Tray 8. Fender Joining Panel:
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 Last edited by Rich76_911s; 01-02-2007 at 07:37 PM.. |
Rich, those pix hurt!!
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Air Medal or two
A+ the bottom of the doors...there is a nasty little fold there that collects water......=rust / pus
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
durn for'ner
Thanks Randy!
I now feel a lot better leaving her in the garage for the rest of our salty winter.
Markus Resident Fluffer Carrera '85 |
Unfortunately I have something to add. Don't forget the Longitudinal areas.
Colin '71 911T |
What a great asset.
Thanks for the education guys. I'm printing it to add to collection I take to look at cars. |
Light,Nimble,Uncivilized
+1 on the head light and tail light buckets. Wish I would have checked there before buying. Sorry, no pic's.
Drago '69 Coupe R #464 |
thank the folks that posted pics - I just kicked it off
From the photos on this thread, I'd say the major places are covered. One place that I've noticed on a few cars is at the bottom of the doors where the skin is welded to the door frame. Moisture gets into the seam from rain or washing and the rust starts............
As much as I'm tired of California and its over-crowding and cost of living, I see the awful things that you east coasters have to put-up with to keep your P-Cars on the road and I think I'll stay here until global warming creates a desert in Maine. Dirty Marty Fallbrook,CA
Here's a few
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Bump for more spots
