lespaul's Avatar
Oil Filter Magnets
Does anyone have any experience using the wrap around oil filter magnets? Are they worth the money?
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 02-01-2007, 09:02 AM
Information Junky
island911's Avatar
No.
(unless you get a shiny sticker to go with)
Search is your friend:
The next cool collar? Would you buy this for $89?
Old 02-01-2007, 09:30 AM
Senior Member
Many cars have a magnetized drain plug, while a lot do not. Could not hurt but bet its kinda like the cool collar where part of it is in the mind of the owner of the car.
Old 02-01-2007, 09:59 AM
randywebb's Avatar
have you looked at yours after an oil change?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-01-2007, 11:08 AM
Autodidactic user
David E. Clark's Avatar
If only someone made a magnetic cool collar! Magnetic aluminum - now there's an idea!
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Very strong magnets are available, probably stronger than the ones included in the products they sell for oil filters. Look for the word, "neodymium". Get 3-4 button-shaped magnets and stick them on the filter. You'll have plenty of change left over for a nice dinner.
Sherwood
Old 02-01-2007, 01:51 PM
len911's Avatar
If you have any old PC disk drives, you can take them apart and remove the magnet that energizes the head assembly. They are the right kind of magnets... Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 02-01-2007, 02:43 PM
Zeke's Avatar
What would be the point of a magnet on an oil filter? I can see the point of having a magnetic plug to catch something before it tore up the oil pump, or in the case of the tranny that has no filter. But why try to catch something that is gonna get caught anyway?
Also, there is a lot of non ferous metal in an engine.
Old 02-01-2007, 03:50 PM
JMatta's Avatar
"If you have any old PC disk drives, you can take them apart and remove the magnet that energizes the head assembly. They are the right kind of magnets... Lou"
Now I know what to do with all those worthless old HDDs I have tucked away. I could make a magnetic filter band and sell it on eBay. Now that's a plan!
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 02-01-2007, 03:57 PM
Milt,
When/if oil pressure is too high, the bypass valve opens to allow unfiltered oil through. Last I looked, the bypass valve is in the filter can.
True, most bearing material is non-ferrous. However, ground metal from sprockets, gears, shafts and chains (heaven forbid) does circulate.
Sherwood
Sherwood
Old 02-01-2007, 04:35 PM
randywebb's Avatar
I'll await some pics of the internals of filters with and w/o the magnets -- should be interesting...
Old 02-01-2007, 04:55 PM
I would imagine they would do the most good at time of break in, no?
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 02-01-2007, 07:45 PM
randywebb's Avatar
sure - people can disclose that in their pics
BTW, I found that a lot of silicon accumulated when I let my '75 (carbed) sit a lot.
Old 02-01-2007, 08:51 PM
Detached Member
Hugh R's Avatar
I have magnetic oil drain plugs on the Aston and the Porsche, and they always seem to have some schmutz on them But your all right, aluminum block, pistons,etc. not a lot of ferrous materials.
Hugh
Old 02-01-2007, 08:55 PM
"not a lot of ferrous materials."
Not that I think a magnetic oil filter will save an engine from certain death, but remember, most of the main engine components are made of a ferrous material, otherwise the engine would weigh about 50 lbs. less. They include:
Crank, rods, wrist pins. piston rings, rocker arm assembly, intake/exhaust valves, valve springs and retainers, camshafts, all chain sprockets, timing chains, intermediate shaft, oil pump gears. Lots of things to wear out when things don't go just right.
Sherwood
Old 02-01-2007, 09:28 PM
randywebb's Avatar
Aston?
If you grow tired of de-coking the heads, I'll take it off your hands...
Old 02-01-2007, 10:17 PM
Tree-Hugging Member
Jim727's Avatar
Look in: http://www.carbibles.com/engineoil_bible.html
Look for: Magnetised oil traps
Culled from the big oil thread.
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 02-01-2007, 11:45 PM
