notfarnow's Avatar
Search help?
I'm trying to read up on 3.2 valve guides.
When I search:
3.2 valve guides
I get results based on valve and guides, but not 3.2
When I search:
Carrera valve guides
I get results based on Carrera, valve and guides
Am I missing something? Can you not search for numbers, or is there a minimum character limitiation? Makes it hard to do searches for specific engine types by displacement.
'03 Carrera 4s
+ a whole bunch of boats
Old 01-11-2007, 11:42 AM
Early_S_Man's Avatar
Porsche Crest
There is a 3-character minimum, and punctuation doesn't work in a search string, or is ignored.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-11-2007, 12:25 PM
notfarnow's Avatar
Thanks for the reply!
That's not much help when you're searching for engine specific info, like 2.7, 2.4, 3.0, 3.2. Might make sense in some applications, but it sure seems like a troublesome limitation.
I wonder if it's a technical limitation, or a parameter that can be set or adjusted.
'03 Carrera 4s
Old 01-11-2007, 01:11 PM
