Mully
Guest
Posts: n/a
Need for speed calc.
I bought an 85 Carrera with 215/45 17s front
and 235/45 17s rear with all else stock.
I know my spedo is off,but by how much.
I blew past a cop laser with no pull over
and my speedo read 80mph,this cant be true!
Old 11-03-2000, 07:54 AM
wckrause
Guest
Posts: n/a
Your tire and wheel combo is just a bit larger than the common 225/50R16. That will make your speedo read a little slower than actual speed. My calculations show that at a speedo reading of 80 mph, your actual speed is 81.
eq: 2 * (width in mm)*(sidewall ratio)/25.4 + rim diameter in inches = tire diameter.
This is approx. the width of the rim will affect actual tire diameter some.
Bill Krause
'79 911SC Euro
Old 11-03-2000, 08:16 AM
JackOlsen
Guest
Posts: n/a
Stock was 215/60 in the rear, on 15-inch wheels.
Try this:
http://www.miata.net/garage/tirecalc.html
Jack Olsen
1973 911 T sunroof coupe
Old 11-03-2000, 09:39 AM
stlrj
Guest
Posts: n/a
Try this calculator:
http://www.thegrid.net/thedrivetrainpage/rpmcalc.htm
Cheers,
Joe Garcia
Old 11-04-2000, 10:04 PM
