Guest
Posts: n/a
Need for speed calc.
I bought an 85 Carrera with 215/45 17s front
and 235/45 17s rear with all else stock. I know my spedo is off,but by how much. I blew past a cop laser with no pull over and my speedo read 80mph,this cant be true! ------------------ |
Guest
Posts: n/a
Your tire and wheel combo is just a bit larger than the common 225/50R16. That will make your speedo read a little slower than actual speed. My calculations show that at a speedo reading of 80 mph, your actual speed is 81.
eq: 2 * (width in mm)*(sidewall ratio)/25.4 + rim diameter in inches = tire diameter. This is approx. the width of the rim will affect actual tire diameter some. ------------------ Bill Krause '79 911SC Euro |
Guest
Posts: n/a
Stock was 215/60 in the rear, on 15-inch wheels.
Try this: http://www.miata.net/garage/tirecalc.html ------------------ Jack Olsen 1973 911 T sunroof coupe |
Guest
Posts: n/a
Thread Tools | |
Rate This Thread | |
