"street legal" harnesses?
I've seen the Schroth "Rally" 4-point harnesses listed as being "street legal" (DOT approved). Anyone run these in their car?
Also, assuming a good seat (eg Sparco Fighter or Roadster, or maybe a Monza) can you safely run a harness like that without a harness bar (assuming you attach to the rear belt points)? |
aren't 4 point harnesses supposed to be really dangerous?? Isn't the rule that you always need a sub-belt?
Irrationally exuberant
Re: "street legal" harnesses?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
well, there is that. From what I've read the sub is to keep the lap down low on the hips so it doesn't slide up and yank your innards in an impact. But if the alternative is a stock 3-point, I'm not sure how that keeps that from happening either. Also, some of the seats have guides for the lap portion of the harness (like the Fighter) so it seems like that might help. Not sure though...
Do we have an FAQ on harnesses/safety? |
Is it really O.K. to mount your harness to the rear firewall and not use a harness bar ?? What needs to be done to reinforce the firewall adequately ?
Friend of Warren
Hey Chris! Nice letter to the editor in Excellence this month!
Kurt V No more Porsches, but a revolving number of motorcycles. |
I know that a 4 or 5 point harness is a pain on the street. The dash controls are out of reach ,heat controls ,radio and such.FWIW ,I dont think that a 4 point system is that bad at our speeds. I would like to here more feedback on this matter though. Randy
The Schroth harnesses are, I believe, the only DOT legal ones out there.
I've got the passenger side ones for my car, the drivers side has been on backorder for almost six weeks. They're DOT-legal, have a label stating so, and have an orange push button to release. They also have a doubled back part of the strap (ASM) thats intended to rip on an impact. The idea is to let your upper body twist like with a 3-pt seatbelt, which is why they're safe to run 4-pt instead of 5-pt. I have substraps for them. I'm using floor mounts and big washers for the lap belts, and the shoulder straps go through my Recaro seats to the roll bar. Now if only HMS would get the damn drivers side back in stock...
1968 911L 2004 Dodge Dakota SLT Plus |
The 4 points ride up because the shoulder belts are attached in the middle of the lap belt. The 3 point is attached to the end of the lap belt, secured to the chassis so it can't move. You may also get some benefit from the shoulder belt tightening the lap belt in an impact, through the latch.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
What Tod said about the difference between no sub belt and the stock belts.
CON: - Ideally, you'd like to have the harness straps as short as possible which this setup doesn't allow. - Requires drilling holes in rear seat. PRO: - No harness bar or shoulder harnesses in the way of putting stuff in the back seat. When I get to the track I unload the rear seats, clip in the shoulder harness belts and go. - Nothing to snap your neck on if the seat bends back in an accident. - Seat can recline for resting. - Folding rear seats up covers eyebolts. I had a rollbar without a harness bar and this setup was a great compromise IMO. -Chris
slope-nz:
With the specific exception of the Schroth set up...there is no 4 point system that is "safe enough" that avoids needing a sub belt. It's not a question of submarining forward...it's a question of shoulder belts causing the lap belt to ride "up" and causing soft tissue damage. You can never predict the impact forces and qualifying it as OK because it's for the "street" is simply bad thinking.... ---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Do you have pics of your install? |
I'd have to go back and look. I haven't driven the car yet with them, since I don't have the drivers one. I seem to remember when I was laying the harness out in my living room it just plugged into the latch.
I run Sparco EVO II's in the car with the Schroth 4pt belts. I think they work fine, the rear is attached to the rear seatbolt mount points but I am thinking of moving them up to the firewall with some reinforcement.
74 911s neverending story. two feet and a jetta for now. |
FWIW,....
We are Schroth WD's and can answer any questions you might have about these kinds of applications. I've used the Street Harnessbelts in my 911 for 20+ years with excellent success,.... ![]() Please e-mail me directly if you need assistance.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Todd,
Here's my setup with the Rally 4. .I got the belts and the Stable Energies Guide Bar you see in the picture from a Reputable supplier in Oregon. While I only use them when I AutoX. I can tell you that I cannot reach any of the conveniece controls when I am strapped in. I have not tested them in a crash so I can't speak for the riding up issue. However I will offer this thought: Sub Straps are commonnly seen in F1 type race cars where the driver is laying down on their back in the seat. In our cars, we sit very straight up and I am not sure how you would slide under the lap belt in that posture.
They sit straight up in stock cars, too, and they ALWAYS use a sub belt. Once again, Wil and I are on the same page. I just said it differently. Last edited by Zeke; 05-21-2004 at 06:32 PM.. |
