-   -   sc wont go help !!!!!!!!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/325868-sc-wont-go-help.html)
gordoncoll 01-21-2007 02:26 PM
any more thoughts on this because I am struggling now. Possibly the leads and plugs?
i really am at my wits end !:(
Rick V 01-21-2007 03:29 PM
To me it sounds like the coil is weak. I am thinking this since the timing light won't light. Are you sure it works?
Cancel the fuel pump and try to start the car. Do thid for about 15 seconds, a couple of times. Don't crank on it longer than that, you don't want to burn up the starter. This will "clean out the cylinders" If it trys to start you are flooded.
Make sure to engage the clutch while doing this, no need to add the trans to the cranking duties.
And an SC rotor rotates counter clockwise
gordoncoll 01-21-2007 03:37 PM
I know the sc rotates counter clockwise ! I have tried with an msd blaster coil and a standard bosch blue coil. Nada from each !!!
So down in the dumps with this ! :( :(
Early_S_Man 01-21-2007 03:50 PM
Gordon,
1. Those plugs sound way, way too cold for an SC engine! Have you pulled them lately to see if they are carbon-fouled? Six fouled plugs can make a coil look weak -- even when it is fine!
2. Have you checked the condition of the green coax signal cable from the distributor? If it has turned brown, or is cracked ... I would suggest replacing it!
3. Have you checked the socket for the CDI unit at terminals #31d and #7 for continuity and 600 Ohms [+/- 10% at room temperature] resistance with a good digital multimeter? There should be a low level 1.0 - 2.0 Volt AC waveform-Voltage signal there during cranking.
Here is more documentation on the 6-pin CDI unit and some troubleshooting precautions:
http://forums.pelicanparts.com/showthread.php?s=&threadid=203100&highlight=cdi+do cumentation
1982 911 Targa 01-21-2007 04:02 PM
have you checked the battery. possible the battery is weak and cant get enough cranking amps to the coil. that was my problem at first. new battery and it started right up.
gordoncoll 01-22-2007 03:20 AM
the plugs are the Porschce reccomended part if you cant get BERU.
I am going to get this bloody car started one way or another !
Gordon
Gunter 01-22-2007 07:15 AM
Originally posted by Gunter
Gordon:
You'll need a few books; the Bentley SC Repair Manual for sure will make you understand more.
You mention that the CDI failed, what do you have now?
If it was running very rough, there could be a vacuum leak like a cracked airbox. Do you have a pop-off valve?
The rough "Bag of spanner noise" is not good and may be due to a tensioner failing. To check, remove the small oil lines on the chain covers and the covers. It's a little tight and requires the removal of muffler and rear tin.
The dual-chains do not break but will make an awful noise when the tensioner fails and allows the chain to become slack.
So, set the engine to Z1, open the cap and see if the rotor points to the notch for #1 combustion. If it is exactly opposite, you are on #4. Just turn the engine CW one turn until you are on Z1 again. Now you are on #1 combustion and the rotor points to the notch.
If you need to correct slightly, do not try to turn the rotor. Instead, open the hold-down nut for the distributor and turn it to make the notch point to the rotor. This is approximate but should be good enough for the engine to start provided it doesn't have a bad vacuum leak, bad ignition parts, wrong fuel pressure.
Baring major mechanical damage, it's usual either fuel or ignition related.
Do you have the Bentley?
What ignition system do you have?
Pop-off valve leaking?
Cracked airbox?
gordoncoll 01-22-2007 07:33 AM
hi,
thabk you for the reply.
I have the Bentley book, which as i say actually said that the direction of the rotor is "clockwise" which I know is wrong!
I am running an MSD 6a
can a pop off valve leak? i didnt think of that.
as for the airbox i havent had it off to see if it is cracked.
Gordon
Gunter 01-22-2007 07:40 AM
O.K. Let the MSD experts chime in.
gordoncoll 01-22-2007 07:43 AM
I am heavily tempted to go back to the cdi to be honest !
Gordon
gordoncoll 01-22-2007 02:21 PM
oh joy of joys. to put the tin hat on everything i think I have now ruined the battery. It only seems to be charging on 3 cells!!!!
moochie 01-22-2007 02:23 PM
maybe that's been the problem the whole time. Let's hope so since that's an easy fix.
gordoncoll 01-22-2007 02:39 PM
I hope so, I really do !
gordoncoll 01-24-2007 12:17 PM
yeeeeeeeeeeeeeeeeehaaaaaaaaaaaaaaaaa
started today !1 had to take the distributor out and reset it, fitted new plugs etc, went fine, timed to 5* at 950 and 25 at 4000 rpm. My only worry is that it is as smokey as can be when I first started it. Could it have too much oil in? would that give me problems with smoke ? thing is this smoke is coming from inside the he's! out of the heater system!
Gunter 01-24-2007 12:35 PM
Sounds good.
Get the long 3mm Allen, read up on how to do it and set the mixture.
Check oil level with engine really hot and keep the level in the middle of the stick, no more!
Remove the airfilter and clean out the oil from the airbox.
Let it run for a while to burn off the excess oil.
If your heater boxes are really rusty, the headers/pipes from the exaust ports may be leaking into the HE?
gordoncoll 01-24-2007 12:42 PM
ah the he's are brand spanking ssi's. i do think the car is overfull of oil though, at top of stick when hot, nice and clean though, interestingly the revs drop when I remove the oil cap, should that happen?
many thanks to all of you here who helped, the distributor setting info was brilliant. SmileWavy
gordoncoll 01-25-2007 02:02 AM
just for good measure i went out this am in the very cold weather, turned the key and bingo off she went runnning like a good 'un:D
moochie 01-25-2007 05:44 AM
Glad to hear all is good!
gordoncoll 01-25-2007 07:38 AM
smoking has now stopped, seemed as if she just needed to be ru for a while. Now to set about the calipers!!
Gunter 01-25-2007 07:56 AM
Yes, RPM will drop about 50 when opening the oil cap, very normal.
If it doesn't drop, it means that there is a vacuum leak in the breather circuit (hose from the case to the filler stud), not good.
When changing oil and filter, fill with 10 liters first, run the engine hot, top up if necessary but not more than the middle of the marks on the stick!
