LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Your installer figured it out. The trick is to use the correct amount of adhesive. To much and it will ooze past the inner seal and to much on the outside will make it difficult to get the outer seal flat.
I like this mod for my car because here in the tropics where it rains alot all Porsches leak except ones with glue in windshields.
Old 08-18-2007, 12:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Well, my body guy seems to think the windshield sits too proud relative to the body with the 993 seal, so he called in a windshield guy. A bunch of windshield guys wouldn't touch the job, and the guy who came out to look at it gave me a whole song and dance about how bad the design is, and how he can't accept the liability of doing a non-standard install. Not having seen the setup, my engineering judgement tells me he is full of it. That said, I have a few questions:
Is this install identical to the 993 install, or does the 993 use of these seals produce a different windshield/glue/body geometry. The glue just connects the outside edge of the windshield to the body, with a little fillet below?
Does the 993 innner windshield seal need to be compressed to install the windshield? My body guy seems to think that installing the inner would leave the outer too far out, and not touching the body. What is the technique for compressing the inner until the glue seals.
Does the outer rubber glue to the inner rubber when the windshield is installed, or is there another system?
Is there any other technique to getting things centered and compressed so I can just get the car back with the old windshield reinstalled, and then fix it myself?
Phil
Phil
89 930 Slate Grey/Black
K27 B+B 1 Bar
shaved gutters
backdated to opening vent windows
Old 09-19-2007, 07:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
Bump. I need a hand here to finish this up. Anyone installed a windshield on a 95 to 98? Did the seal need to be compressed?
Phil
K27 B+B 1 Bar
shaved gutters
Old 09-20-2007, 02:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
I got one installed but I haven't seen the car yet so I can't say how the fit is I can ask the shop on Monday about it and get you some answers.
Old 09-20-2007, 02:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
Was it installed in a 993 car, or was it an upgrade to an earlier car? The big question is if the rubber needed to be compressed.
Phil
K27 B+B 1 Bar
shaved gutters
Old 09-20-2007, 02:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Bump.
Phil
K27 B+B 1 Bar
shaved gutters
Old 09-20-2007, 10:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
newb.
eimkeith's Avatar
philipguziec, the 993 winshield with the 2 correct 993 seals should work just fine in your car. Check Matteo's thread for pictures - we used 993 front and rear winshields and correct seals, and 993 quarter window seals with the 1974 quarter glass on that build.
Additionally, we used a 964 front windshield and 964 seal in a a 930 build recently - that thread is in the 930 forums here on Pelican.
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 09-21-2007, 04:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
AirBorne!
Jack
Do you get that cheap windshield glass because you are a frequent repeat buyer? If so that means you're spending way too much time on the track and good that you're lapping all the backmarkers....
wj
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 09-21-2007, 06:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Phil the seal and glass are 993 pieces in my 930
Old 09-21-2007, 08:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
philipguziec
The inner seal just fits over the flange. Once it is in place you put the adhesive on the body to the outside of the inner seal. It should be obvious where the adhesive goes at that point. You just place the windshield in and seat it to the adhesive. That stuff is very sticky and the only thing you need to do is place settling blocks at the bottom of the windshiel to keep it from sagging down untill the glue is dry. You then snap the second seal into the groove in the 993 windsheild. You can do this without adhesive as a dry run to check the fit for the second seal. It should be flush with the body. Refer back to the picture I posted that shows the fit.
Old 09-22-2007, 09:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
Thanks for all the help guys. This is the last thing. He's talking about gluing in the outer seal, and it not sitting flush, so I think we didn't have a 993 windshield. I'll see if I can get him to do it.
The windshield itself has a groove in it, correct?
Phil
K27 B+B 1 Bar
shaved gutters
Old 09-25-2007, 05:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Sounds like my body guy and I will be doing the windshield ourselves. He got it to fit.
Anyone know the exact type of glue, part number, tube size, and where to get it?
Phil
Phil
K27 B+B 1 Bar
shaved gutters
Old 09-27-2007, 01:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Woohoo, it's done. The 993 windshield fits and looks great on an 89 930.
Next PITA problem. The rear view mirror clips on differently on the new windshield.
The windshield has a square-ish male fitting. I ordered a mirror from our host for a 98, and it has a male tongue and clearly doesn't fit. Pelican actually lists the same part number all the way from the 78 to 1998.
Any idea where I can get a mirror that fits my shiny new 1998 windshield?
Phil
K27 B+B 1 Bar
shaved gutters
Old 10-30-2007, 06:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
rnln's Avatar
With 993 rubber weather strip? Does it look great? Does it go in straight forward or you need any trick? Can you tell a little more deatail, or can you write an instruction?
Thanks phil.
Fat butt 911, 1987
Old 10-30-2007, 06:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Yep, the 993 with the rubber strip drops right into the 89 window frame. The instructions are excruciatingly clear in this thread.
I think it looks great, and it quiets down the wind noise quite a bit. Of course, I shaved the rain gutter at the same time, so I'm not sure which change reduced the wind noise. I bet both.
I also filled the antenna hole in the fender. The in-glass antenna works okay, but I do have some AM reception problems, and problems in high density city areas with the FM.
Phil
K27 B+B 1 Bar
shaved gutters
Old 10-31-2007, 02:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
newb.
eimkeith's Avatar
pictures...!
keith
r gruppe #436
Old 10-31-2007, 03:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
This is really good stuff guys.
I like the idea of going for a 993 window, both to avoid damaging a 964 window while pulling it in place as well as to make sure I have no leaks.
My 964 window is out now due to a crack and the need to redo the lower corners of the window frame (rust).
@ Phil and Racey:
Before installing the outer seal, what did you do with the space between body and the glass (the area that is normally filled by the traditional rubber seal) ?
Is there a way to make sure that no water gets to sit in the lower corners anymore ? For example by entirely filling it with sealant before attacheing the outer seal to the window ?
Better a good one for a lot of bucks, than a bad one for little
Old 11-02-2007, 04:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
When you glue in the 993 windshield, I don't think any water will get past it to rust that area. Bacially, you're filling the area with the glue because the 993 windshield pushes the glue out to fill the whole gap.
In my case, we put a little too much glue in and some of it got over the groove that accepts the outer seal, so we put the outer seal on before the glue dried to make sure we could get it in.
Phil
K27 B+B 1 Bar
shaved gutters
Old 11-02-2007, 08:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
Thanks for the clarification; I could not get an idea of the size of that gap under the outer seal. If if fills up the entire area, that sounds good.
Have you checked the difference in size between the 964 and 993 windows ?
Are they very different ?
@Phil: what did you mean with "I shaved the rain gutter" .. ?
Old 11-02-2007, 08:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
You can always go around the window and add glue if necessary to completely fill the gap.
I didn't pay attention to the size difference, but the 993 fits the outer opening, which is constant, I believe, from the early cars through the 993.
I had my body guy cut the rain gutter off, a foot at a time, and weld the three pieces of metal that meet in that seam together. The result is a smooth look, less wind noise, less drag, and better downforce on the tail. You need to take the interior out, and repaint the car. You can search for shaved gutters to find threads about it.
Some people find this offensive for some reason, and are paranoid about rain water runoff. I, however, have not had any such experience. My body guy now wishes he had shaved the gutters on his car.
Phil
K27 B+B 1 Bar
shaved gutters
Old 11-02-2007, 09:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
