Apprentice 911 Mechanic
In 1984, the M491 option.
Did this option include a limited slip differential?
In 1984, Porsche also introduced the M491 option. Officially called the Supersport, it was commonly known as the "Turbo-look". It was a style that resembled the Porsche 930 Turbo with wide wheel arches and the distinctive "tea tray” tail.
Old 01-31-2010, 06:22 PM
Bill Verburg's Avatar
no, a 40% lsd was a separate option, M220
Bill Verburg
Old 01-31-2010, 06:43 PM
lsd
Is it expensive to add this to a 1984 911?
Old 01-31-2010, 06:45 PM
GaryR's Avatar
Send a message via ICQ to GaryR
About $1500 + labor for a Guards unit set to whatever % you want last I looked..
Gary R.
Old 01-31-2010, 07:13 PM
I have the original window sticker for my car. Kind of odd. No sport package, spoilers chin lips etc. But the guy ordered it with a LSD. Lucky me!
O2 In Sully We Believe
Old 02-01-2010, 06:10 AM
GaryR's Avatar
Mark - ever have the clutch pack in it checked/replaced? I have heard they are fairly short lived (if it's original I would think it needs a rebuild). Guard will do it, for one.
Gary R.
Old 02-01-2010, 06:40 AM
-84 Carrera's Avatar
I also have the diff (factory option), how can you tell if it needs to be serviced?
/C
Old 02-01-2010, 07:13 AM
GaryR's Avatar
/C
Really don't know (assume a visual inspection is one way) but I bet a call to Guard will get you an answer if no one pipes in here...
Gary R.
Old 02-01-2010, 07:16 AM
Peter Zimmermann's Avatar
/C
No service required. If you detect "chatter" during city driving while going around corners, it's possible that your diff needs an additive designed for limited slip. Chatter will cause premature wear, so be sure this doesn't happen.
Keep the Shiny Side UP!
Pete Z.
Old 02-01-2010, 07:18 AM
GaryR's Avatar
So Peter, are you saying the clutches never wear out in normal-heavy (track) use?
Gary R.
Old 02-01-2010, 07:21 AM
I use the swepco oil. Is that the right kind for the limited slip diff?
Old 02-01-2010, 07:23 AM
