This injector may work, I know the bosch 364 is a decent replacement and this one cross refs to it. I have tested the 364 injectors in car and validated they are correct with WBO2 across many running conditions, including WOT sweep testing. If you can locate a set of 364 injectors those work perfectly. See post #206 in this thread.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 05-18-2020 at 01:29 PM.. |
I’ve been running 0280155784’s in my 84 3.2, completely stock, zero issues.
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
-Wayne
Maybe adding something with the Lucas brand name would be bad juju?
https://www.fiveomotorsport.com/53212101-fuel-injector/ John Last edited by jjeffries; 07-28-2020 at 10:34 AM.. |
First off, sorry for going so far back in an old thread, but..... Sal, is it possible to re-post the two schematic PDFs (911_dig.pdf & 911_an.pdf) as the links are dead. Thank you!
John Flesburg 2016 981 Boxster S.................| 1983 911 Turbo - (White) 1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver) 1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?) 1971 914 (TBD)..................... | |
PM me your email and I can send you a copy.
Gilles RoW 88 Carrera coupé |
Just a quick bump.
Wanted to see what my alternate routes would be to get some decent injectors before I pull mine to send out, again, to get cleaned via RC fuel injection. Thinking I got some contaminants in mine before I fully overhauled the fuel system. Chatting w Steve Wong about a current issue and he's leaning toward the injectors... I'm going to test them this weekend using an infrared temp tool to test cylinder head temps to see which one(s) may be misbehaving... but curious to see if anyone has links to options they've used, since the links in this thread are all expired. I googled, 0280155784 and immediately got served an Amazon link with 6 for $45... not really instilling confidence... Also saw the GB brand our host sells, aside from the $15 core... Curious to see if anyone's been running them successfully. My build: 87 Carrera SW ReFlowed 28pin ECU SW CAT, sport muffler 28pin chip Full fuel system redo AEM wideband Fabspeed Supercup Muffler My build is farely tame, just dealing with an intermitent fuel mixture issue that's now fully come down to the injectors. Thanks, Ian |
One referenced recently has been repairing DME ECMs and providing personal help to Porsche dealers/independents & 911 3.2 owners for over 30+ years. You could always call them for help, they don't charge Pelican Parts users for Porsche help. Don't replace unnecessary parts and waste time and money.
Dave Last edited by mysocal911; 11-25-2023 at 04:07 PM.. |
Not folllowing. Any insight on injectors?
It's very unlikely that all the injectors are bad, so disconnect one injector at a time to see the effect.
Removing and comparing spark plugs can help in evaluating injectors. Doing the shotgun approach to troubleshooting wastes time and money. Furthermore, the 911 3.2 injectors are low impedance and unique, not like the high impedance type used by all vehicles now, and very critical to proper engine operation and performance. Porsche 911 3.2 OEM injectors are very rare, and as such difficult to replace. Using the wrong injectors have caused major headaches for some.
Dave Last edited by mysocal911; 11-25-2023 at 04:36 PM.. |
Loren gave me impeccable service, quick turnaround, at a more than fair price. my real world experience.
Great info. I’m just really looking to replace all six injectors. Not looking to send these originals back out for another cleaning.
Call Pelican Parts, they'll help you.
Dave |
Just got a reply from the guys at RC Engineering and they let me know these injectors will work on a 3.2
Model #PL2-0250 https://www.vividracing.com/engineering-250cc-peak-hold-low-impedance-injector-p-151344016.html I am going to give these a try and report back. |
+1 for new Lucas units.
I've been using the Lucas units available on Ebay for about 2 years in my 87 now without issue. I believe I found them in this very thread. They were $299.99 for 6 back then, and are now $349.99. Ebay for $349 MFG for $507 https://www.fiveomotorsport.com/fiveomotorsport-255cc-24lbs-porsche-bmw-original-equipment/ |
I have huge collection of fuel injectors
And can say with 100% certainty which I personally used in 3.2L carrera Bosch 0280150157 , 0280150201 , 0280150352 , 0280150165 I used these ones personally , tested them new out of the box side by side they are basically the same injectors as Bosch 0280150158 . keep in mind the injectors are not manufactured to flow 100% identical . if you put 8 brand new injectors and put them through a dynamic test , especially with lower MS opening times that would correspond to a normal driving , even NEW Bosch German made injectors would be flowing within 5 % of each other. All above injectors have very similar or identical dynamic flow spec . There are also 0280150360 and 0280150364 looking at their spec even though I never tested them I can confirm they will work too. By the way the metal cap can be easily ( but carefully ) removed and a normal plastic cap fitted . But please use genuine Bosch kit , not Chinese crap . The kits can be bought from pelican . NEVER use Chinese o-rings too buy Bosch ones , they are expensive but will last 3 times . Contact me if you need help with Genuine Bosch injectors , I can help |
