I have 6 injectors from a Suzuki bike with unknown flow rates.
Can I flow them myself to see what I have?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Jon,
I would always suggest servicing your stock 158 injectors first, I sent mine here: Motor Man Fuel Injection Supply Howard & Debbie Haack 6000 W. Weidman Rd. Weidman, MI 48893 989-644-2695 989-621-9965 cell fuelinjectorman@aim.com http://www.fuelinjector.citymaker.com Howard did a great job on my stock 158s and I'm using these freshly serviced injectors to setup my AFR. It has been a long road to setting up the AFR in my car. First I had a faulty FuelPressureRequlator that had my FP at 3.5 bar rather than 2.5. I have replaced the FPR and am now at stock 2.5bar FP. But when I fixed the FP the custom chip in my car was way to lean! So this caused me to dig in and learn the Chip maps and howto tune them. I have been tunning my AFR by burning new chips. Right now I'm finishing my WideOpenThrottle (WOT) map fine tuning, I have the 1000-5000RPM range spot on at 13.0 AFR and am now working on tuning the 5000-6800RPM range. I moved my rev limit to 6800RPM via the chip maps. In order to do all the AFR recording I installed a WideBand O2 sensor and monitoring system in the car that feeds live AFR data as well as several other signals (like RPM) to a laptop. This allows me to run test runs on the road at WOT in 2nd gear from 1000RPM right up to rev limit of 6800RPM. Then I review the log and fine tune the WOT map. Then back to the road for another spin. It is very time consuming process but in the end I can really notice the diffrence in the car. Actually the log also contains time so I see the 2nd gear run getting faster since the first early runs. I intend to put the 360 injectors in but not till I have AFR properly set with the 158s as a baseline. I just need more time. If you are intrested in the details for installing a WideBand O2 sensor and monitoring system into a Carrera then see my other post: Wide Band O2 + data logger for 84-89 Carrera I actualy installed the WBO2 by piggy backing it onto the DME, I did not alter any wire harness in the car to do the install. But I did heavily modify the DME.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Dfink,
I agree that in order to test an optional injector we MUST HAVE a baseline for the performance of the stock 158. This is why I'm tuning my chip with known good 158 injectors first, the goal of the tune is to obtain a 13.0AFR at WOT across the 1000-6800RPM range. Once the tune is done and the graphs recorded via my WideBandO2 I will put in the 360 injectors and record a simular run. As for the 360 tip design and reduced heat soak, I only passed along the information I received from the Injector supplier that serviced my stock 158s and then provided me with the 360s for trial purpose. [QUOTE=dfink;3587574][QUOTE=scarceller;3423976]the tip was redesigned by Bosch to help solve a heat soak issue that exists with the old plastic tip injectors. The issue is that while the injector is running the fuel keeps it cool but once you shutdown a hot engine the injectors heat soak quickly and any fuel left in/on the tip orfice quickly evaporates and leaves behind a film/particles that result in clogging if the engine exposed to short driving cycles. The idea behind the new metal tip is that the tip was designed as a heat sink to help reduce this problem. Quote:
heiliges blechle!
I replaced my injectors last weekend with the 159s from 5-O (thanks ianc) I was having a no-start problem and after 112K miles I thought what the heck. they probably need replacing anyway. I found the no-start problem but then immediately had a flat tire
so I only got to drive ~40 miles.
'84 M491 '07 Silverado '75 Suzuki GT550 2-stroke triple '02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train |
Czar of C.R.A.P.
scarceller;
sounds like a good plan. It will be interesting to see how they compare.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Are your bike injectors Bosch? if so what number are they? I have large spec list for bosch injectors.
First they must be low impedance 2-3ohms coil resistance. They can not be the more popular 12ohm coils.
Monkey Butt Forespin
I'm going to go through the thread & re-read all the details, but...
The V6 Taurus SHO (3.0L / 3.2L, 1989-1995) uses a 24 lb-hr low-impedance injector. I have sets of these sitting on the shelf, and they can be had used for about $20-$50 / set of six (not a for-sale, just stating what the typical market for a set runs in the SHO crowd) I'll see if I can cross the specs in the Ford Shop Manual I have also. I know Bimmer guys have used the SHO injectors as an upgrade on certain models, FWIW. There are pink tops (3.0L), which are slightly less than 24 lb/hr, and purples (3.2L) which are slightly more. The rail-side diameter is smaller than the generic Accels (which I used 48 lb-hr versions of for my 'charged SHO). Attached is a photo, haven't pulled a 911 injector yet, so I don't know how it compares.
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
They are going on a 3.2, but not a motronic.
I have experimented with many different saturated injectors with different flow rates and have come to the conclusion that the stock injectors are (believe it or not) too big for good throttle response and, in reality, tend to bog performance throughout the rpm range. So far the injectors that work best and really wake up my 86 3.2 are GM Multecs that are found on Chevy 3.1 V6 engines. The have a superior spray pattern than the stock pintel type Bosch injectors, so they idle much smoother and have more than enough flow on the top end to convince my seat dyno. ![]() ![]() Which also happens to be the same injector design with a four hole director plate that is currently being used on the 996 M96/03 engine. The only other modification needed to make the saturated injector work on the 3.2 engine is a start relay for additional fuel for warm starts. Cheers, Jose' |
Jose,
Your comments are pretty interesting and makes me want to try out the GM Multecs. Could you deliberate on the reason for a start relay and how to do it? Thanks!
'87 3.2 Targa |
The purpose of the start relay is to compensate for the higher impedance of the GM injectors, because without the relay, the engine will not get enough fuel to start when warm.
I wired the relay by grounding #85, yellow (#50) ignition starter wire to #86, CHT input on #30, CHT output on #87a and a 1K resistor between #30 and #87a. Meanwhile, I have replaced the GM Multecs with a set of injectors from a 3.3 V6 Dodge Grand Caravan and am finding that these injectors work even better than the Multecs. Cheers, Jose' ( orighinally from the Philippines ) 74 911 w/86 3.2 & Mopar injectors |
Interesting stuff Jose, do you have the ability to log your AFR's to see how the different injectors are affecting your mixtures?
Jon |
No, just my nose up the tailpipe which turns out quite accurrate along with a very sensitive seat dyno.
Jose, you seem to be an expert at this.
Is the 'start relay' just a modification of the DME relay without installing an additional relay?
'87 3.2 Targa |
The start relay is an additional relay that I mount on the left side fire wall near the fuel filter. I'll post a picture soon. Jose |
Jose,
I have been toying with difrent injectors as well. But my car has a a Wide Band O2 sensor and complete monitoring system. It allows me to fully record AFR, RPM, Throttle Position Switch and Air Flow Meter signal and anylize all these against each other. See this thread for my WBo2 setup: Wide Band O2 + data logger for 84-89 Carrera Bottom line is I have a well tuned Carrera EURO 3.2L that has a custom chip also has stock 159 injectors, I know exactly what my AFR curve looks like at WOT with the stock injectors. I also know what my AFR is at idle. This means I can install any injector and compare it against others. I have done a little of this so far with not excellent results. But I'm very intrested in talking to you about your high impedance results and maybe even trying a set of high impedance injectors. I have a good source for injectors that I can obtain them on loan. Please contact me via PM with phone number so we may chat. Thanks.
Czar of C.R.A.P.
Jose,
I just finished reviewing the drive circuitry that drives the injectors in the DME, turns out you are correct you can drive high impedance injectors without doing any harm to the DME. The 6 injectors are ALL driven by one signal that is a pulsed duty cycle ground signal. This means all injectors have a constant 12volts on one wire and then the other wire is pulsed to ground and the pulse width varies to increase or decrease fuel spray. The driver for this signal is a Darlington type NPN transistor part #RBDT65A and the device is good for 12amps current. So if low impeadance injectors at worse case are 2.3 ohms then 6 of them in parallel would equal 0.38 ohms for a total current draw of about 32amps at 12v or about 39 amps at 14.7V. But of course you would only draw that much current if you applied a solid ground to one side and 12v to the other. But these injectors are duty cycle driven and the current is never that high. Now most high impedeance injectors are 12 ohms or above for a total of 2ohms if you have 6 in parallel. These would only draw 6 amps substatially less than the 39 amps of the low impeadance injectors. For these reasons I agree that you run no risk of damaging the DME box with hi-impeadance injectors. Do they run the same? I'm not sure, we would need to test the results with WBo2 monitor. But Jose already has confirmed that the car runs and seems to run well. here is the injector drive circuit right from the DME schematics: ![]() Jose, one other question: I'm a little confused about how you are using the relay you mention to drive the injectors during startup. Could you draw a schematic of this and post it. Or try to explain what exactly this relay is doing to the injector drive line? These injectors already have 12V on one leg during crank and running. So what does this relay do? Are you just trying to fool the DME to think the engine is cold by disconnecting the CHT sensor line? is that the idea? Thanks.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 02-05-2008 at 06:29 PM.. |
Have a look here, ytou might find some info http://www.msefi.com/viewtopic.php?t=2576
Robert Currently Porsche less (but the wife has 2) |
Czar of C.R.A.P.
http://www.msdfuelinjection.com/ecu_compatibility.html
