Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Ulrich |
Wayne is mistaken ... the Sway-A-Way parts for '69 - '86 models look just like the pics in the Weltmeister site, here:
http://www.weltmeister.com/ProductDetails.aspx?productID=372 I have had them on my car for 20+ years ... no problems!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I hope you're able to get a refund or the correct parts. Good luck with it.
Could these be Sway-A-Ways for a 930?
FWIW, I've had SAW adj. spring plates on my car for over 10 years. Not hi-tech, but perfectly adequate. Sherwood |
Author of "101 Projects"
I do appear to be confused by this, I will have to take a look at them when I get them back here. Installed on your car there, they certainly don't look correct at all.
I'll have Scott (catalog man) take a closer look and post his findings here. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
You already have the factory adjustable spring plates. You just need to buy the skinny wrench to to the adjusting with.
-Andy
72 Carrera RS replica, Spec 911 racer |
Ulrich |
OK, I did some investigating and discovered what happened. We ordered the wrong part from our supplier. The part that you received was, as some mentioned here, the G50 part. We will be happy to ship you the correct part and we are sorry for our error -- I'm sure it's maddening. I will change our database so that it doesn't happen again to anybody else.
Sincerely, Scott |
Scott,
Thank you but I have already installed my stock spring plates with Neatrix bushings. At this point please just refund the money. It's no problem I have ordered from you guys many times before and this was the first glitch. Ulrich |
Scott,
I forgot: I received a return number from Pelican and returned the package via UPS on Thursday. Ulrich |
